evo MUT values
evo MUT values
Postby mlr » Tue Oct 03, 2006 2:09 am
0x80
0x81
0x82
0x83
gives your ecu requestid
mlr
Postby AutoXer » Tue Oct 03, 2006 3:55 am
What is an "ecu requestid"? I am not a newbie, I am just not sure what your are refering too.
AutoXer
Postby mlr » Tue Oct 03, 2006 5:58 am
It is your ecu serues number - the number used in ecuflash xml definitions -u can see it in ecuflash ->Rom info ->internal ID
Could be usefull for datalogger soft writer do distinguish wich pids of MUT does the current ecu support.
mlr
Postby MalibuJack » Thu Oct 05, 2006 12:30 pm
Thanks, exactly what I needed..
What is the expected response and the init prior to sending the string?
Or is it still 0x00 @ 5 baud, then send those bytes and wait for a 4 byte response?
Also which baud rate? MUT or OBD-II?
MalibuJack
Postby MalibuJack » Thu Oct 05, 2006 12:34 pm
You should have forwarded me this info when you came across it on Aktivematrix.. This kinda stuff is really relevent for my work. :)
MalibuJack
Postby S54fan » Thu Oct 05, 2006 2:13 pm
He did post it on Aktivematrix, but I didn't understand when he said "gives you your request ID" until I saw this post.
Postby MalibuJack » Thu Oct 05, 2006 3:26 pm
Obviously he meant ECUID.. It never clicked with me either.
Somehow I completely missed it.. :)
MalibuJack
Users browsing this forum: No registered users and 34 guests
