MUT high speed (custom baudrate) datalogging
Postby mlr » Thu Sep 28, 2006 8:47 am
About 2 weeks of my free time at office :) and home I devoted to evo ecu disassembling. The first goal was to discover load pid and writing patch for "correct" launch control.But by the way i found some interesting. Heres one of the first usefull achievements - found OBD and MUT baudrates. Heres the definition for the most popular 94170008 ecu - sometime I'll make definitions for other ecus.
How to use. If your flash is 94170008 -unzip my definition to ecuflash mitsu folder (dont forget to backup the original) , open your rom and u'll see new params under MISC. Change the BAUDRATE2_MUT and reflash the ecu.
Then start evoscan and put this value in baudrate window (15625 by default)
I tested 62500 baudrate logging - all Ok -engine runs - no errors.
Enjoy highs speed logging
copy sent to evolutiom.net ,aktivematrix.com
94170008.zip
94170008 ecudefinition with custom baudrates.
(1.74 KiB) Downloaded 654 times
mlr
Postby radsdau » Thu Sep 28, 2006 4:17 pm
Leaping horney toads batman!
Well done!
Postby hexman » Thu Sep 28, 2006 4:49 pm
What do you mean by correct launch control?
Nice work by the way!
hexman
Postby xswrex » Thu Sep 28, 2006 10:21 pm
hexman wrote:What do you mean by correct launch control?
LC uses fuel cut, ignition would be better :wink:
this is the HACK OF THE YEAR !
xswrex
