Postby c-spec » Sun Jun 11, 2006 5:03 pm
alwaysinboost wrote:same here... I check this thread daily for updates. I'm sure it will be worth the wait.
+1
c-spec
Postby donour » Mon Jun 12, 2006 10:26 am
bump for an early snapshot of the code. I'd really like to see working code for the logging protocol.
pretty please. :)
cheers
d
donour
Postby Evo4Mad » Mon Jun 12, 2006 11:01 pm
Yeah I'll be releasing a version by the end of this weekend for sure. I have a lot of other programming to do, I'll try and give this the attention it deserves :) and my waterpump needs replacing on my Evo4, that will take a couple of evenings to sort out :)
Postby the-moss2 » Tue Jun 13, 2006 4:30 am
Evo4Mad wrote:Yeah I'll be releasing a version by the end of this weekend for sure. I have a lot of other programming to do, I'll try and give this the attention it deserves :) and my waterpump needs replacing on my Evo4, that will take a couple of evenings to sort out :)
You're killing us man!!! :)
But we all really appreciate the time and effort that has gone into the project.
the-moss2
Postby sweetJesus » Tue Jun 13, 2006 10:48 am
i havent felt like this since i was a wee lad, waiting for xmas to come..
:D :D :D
sweetJesus
Postby andenbre » Tue Jun 13, 2006 7:39 pm
hell if ya lived near me I would change that water pump for ya
andenbre
Postby dsm95hybrid » Wed Jun 14, 2006 7:56 pm
So who is flying to New Zealand to swap waterpumps so he can concentrate on program completion? :)
dsm95hybrid
Postby Evo4Mad » Thu Jun 15, 2006 1:37 am
UPDATE:
EvoScan Supported Hardware:
1) I will be putting up a cable for sale that is FT232BM USB cable for the EvoScan datalogger. ($65US) (for Evo7/8/9 I would recommend the OpenPort cable below as it supports EcuFlash factory ecu tuning)
2) OpenPort cable 1.3M uses a built in FTDI FT232BM USB-Serial adapter.
- Colby Boles - http://www.tactrix.com/ ($89US)
- advantage of this cable is that it supports ecuflash only for Evo7/8/9
3) HomeMade for Electronics minded people: beware not many OBDII cables support 15625baudrate.
What you can do is buy a FT232BM($20US+) based usb-serial adapter because this chipset supports any baudrate you like, the PC standard comport cant physically support 15625bps, with the usb adapter then convert the serial adapter voltage levels to obdII levels +0v/+12v using a optoisolater circuit like Andy Whittakers or Jeff Noxon, or use a MAX232 chipset circuit like MMCd.($20US)
EvoScan Registration:
1) EvoScan Registration will be $15US ($20NZ)
- this will allow me to purchase expensive third party charting and gauge controls to make this the best looking and best functioning datalogger around.
- with registration you will get unlimited future releases.
- if you want a new feature added, this will be added for you with priority.
- you will get emailed latest updates released every week.
- you get access to the source code (personal use only).
- Using this datalogger will allow you to successfully see what your car is doing before and after you use tools such as EcuFlash or Aftermarket Controllers such as SAFC-II to tune your car. And you can save and send your results to your openecu buddies to oggle over, and others with EvoScan can even play back your results without being plugged into a car.
- Using the alerting features of EvoScan could alert you to a bad tune or bad fuel, i.e Detonation Knock Counts, Temperatures, A/F ratios and we all know what happens to an engine under extreme detonation or extreme lean conditions.
Supported Vehicles:
1) Mitsubishi Lancer Evo IV/V/VI/VII/VIII/IX (Any serial obdII adapter that will support 15625baudrate)
3) Other miscellaneous 1996+ Mitsubishi OBDII Vehicles (support to follow as people test it on their cars - I'm expecting a lot of these vehicles to already work with this software)
3) Subaru SSM protocol support to follow (Any serial obdII adapter that will support 4800baudrate)
4) Nissan vehicle (I have a lot of Nissan protocol information - support to follow)
Postby Nuked » Thu Jun 15, 2006 2:14 am
Do you take paypal? :D
Looking forward to registering!
So will the 1.3m cable work with the SSM when you get it going? I own both a Subie DBW and Evo, so would be great if so.
Thanks!!!
Jason
Nuked
Postby AutoXer » Thu Jun 15, 2006 3:15 am
Will this work on an EcuTek flashed Evo?
AutoXer
Postby S54fan » Thu Jun 15, 2006 4:48 am
Forming an orderly queue :)
Postby jmoudry » Thu Jun 15, 2006 9:12 am
This sounds like a great value for $15. I can't wait to try it out!
jmoudry
Postby andenbre » Thu Jun 15, 2006 10:57 am
ad me to the list. I will purchase as soon as its available
andenbre
Postby laakness » Thu Jun 15, 2006 11:08 am
*patiently waiting*
laakness
Postby djmikeymike » Thu Jun 15, 2006 11:40 am
im on the list :D
djmikeymike
