Can`t read EVO5
Can`t read EVO5
Postby Falcon » Tue Jun 25, 2013 11:17 pm
Hi, all! Trying to read Evo5:
[20:26:19.843] using metadata XML ID read_evo5 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml
[20:26:19.890] J2534 API Version: 04.04
[20:26:19.890] J2534 DLL Version: 1.00.3719 Dec 28 2012 23:38:48
[20:26:19.890] Device Firmware Version: 1.12.3688
[20:26:19.890] Device Serial Number: TAHhQTbe
[20:26:22.171] sending init sequence 2
[20:26:22.171] got 0x10 response instead of 0x11
[20:26:22.171] sending init sequence 3
[20:26:22.515] entering bootloader
[20:26:22.515] sending kernel size (2029)
[20:26:22.515] error sending kernel size
[20:26:22.515] interface close
They are reflashable as i know... or i mistake?
Falcon
Re: Can`t read EVO5
Postby ayashiko » Thu Jun 27, 2013 11:24 am
boot PIN, please make sure the voltage should be 16 - 18 volts
ayashiko
Re: Can`t read EVO5
Postby todd-w » Fri Jun 28, 2013 1:30 am
openport 2 ???
todd-w
Re: Can`t read EVO5
Postby Falcon » Wed Jul 10, 2013 3:05 am
Sorry, for long response...
Yes i use OP 2.0.
Boot Pin must have 16-18V always?
Falcon
Re: Can`t read EVO5
Postby Sasha_A80 » Wed Jul 10, 2013 10:17 am
got 0x10 response instead of 0x11 - it's not H8/500 device
try mitsukernelocp
Sasha_A80
Re: Can`t read EVO5
Postby Falcon » Sun Jul 21, 2013 3:55 am
Didn't understand anything...
Falcon
Re: Can`t read EVO5
Postby todd-w » Thu Jul 25, 2013 2:13 pm
is it possible the ecu was changed for evo7/8 type ecu
todd-w
Re: Can`t read EVO5
Postby Falcon » Fri Jul 26, 2013 4:07 am
No. There was the Evo4 Ecu before. Then it was replaced by Evo5 ecu
Falcon
Re: Can`t read EVO5
Postby todd-w » Sun Aug 04, 2013 4:53 am
try reading as evo6 tme 7203 or have a look see what the ecu board number is
todd-w
Users browsing this forum: Google [Bot] and 26 guests
