Yamaha Waverunner ECU
Re: Yamaha Waverunner ECU
Postby Bruce Willis » Fri Sep 14, 2012 1:36 am
MMC module 2 can read by K line 8102 CPU
Bruce Willis
Postby Hexec » Fri Sep 14, 2012 10:24 am
Bruce Willis wrote:MMC module 2 can read by K line 8102 CPU
In an earlier post you said that the hardware requirements are open port 2.0 + senselock key.
Sorry I'm still very much a noobie. I'll get this stuff quickly, just need a bit more help.
Is open port 2.0 the interface device (ECU to PC hardware)?
And
Senselock key is some sort of key for the PC to make the MMCflash software functional?
Hexec
Postby Bruce Willis » Sat Sep 15, 2012 5:04 am
You read that right. The only problem may be to find the ECU pinout
Bruce Willis
Postby Hexec » Fri Oct 13, 2017 11:48 am
The ecu is easily dumped. I managed to be ale to read the ecu and write to the ecu successfully. I've found most of tables and was able to remove boost limit and adjust rev limit. In fact, I also found the table that defines the learner mode limits. I'm looking for a dump of a popular commercial dump to compare my changes. Anyone out there willing to share?
Hexec
Users browsing this forum: Bing [Bot] and 18 guests
