Help: 08+ STi (SH7058 CPU) reprogramming count limit?
Postby warmup » Sun May 30, 2010 12:32 pm
I've heard that MY08+ STi's ECU has a reflash count limit, it is around 100 times. Then I found a datasheet of SH7058(the CPU of 08+STi's ECU),
it says the min reprogramming count is 100, and no max count guaranteed.
So after 100 times of reflashes, the result of erasing or writting to ECU will be undefined.
Now I have reprogrammed my ECU for 80+ times, should I worry about my ECU's lifetime or it is just a theoretical limit ?
Anyone met erasing/writting issue after 100 times of reflashes on 08+ STi?
warmup
Re: Help: 08+ STi (SH7058 CPU) reprogramming count limit?
Postby radsdau » Sun May 30, 2010 4:32 pm
I've reprogrammed ECUs using SH chips several hundred times with no problems. I've heard of people on this forum going over 1000. You should be fine.
Postby warmup » Sun May 30, 2010 11:23 pm
Thanks for the reply, it really makes me feel better :P
and i found this:
The ECU is rated for 100 flashes. However, latest Subaru STIs use the same ECU and some guys have flashed them more than a 1000 times without any problems.
http://wiki.answers.com/Q/Which_ecu_is_fiited_to_the_mazda6_mps
so things seem good now :D
warmup
