Multiple scalings in one table? Possible?
Postby Ceddy » Fri May 14, 2010 8:24 pm
I am adding a Window Switch mod for the stock emissions solenoids, to control aftermarket devices.
Is it possible to have multiple scalings in one table, by manually editing the .xml?
Like having tables inside a table?
Something like this setup:
Fuel Pressure Solenoid
RPM -> min, max
TPS -> min, max
Load -> min, max
Speed -> min, max
Knock -> min, max
Boost -> min, max
I would like to have one table, instead of six separate ones, as that would make it confusing to use.
Thanks for any info.
Ceddy
