Checksum question
Checksum question
Postby student_scheire » Fri May 07, 2010 6:54 am
I've got some trouble with a 53040007 rom.
ROM pulled successfully from the ECU but unable to modify the maps.
Ecuflash recognizes this rom as a 53040007 but doesn't show any maps with several different xmls (that can be found on openecu.org), none of these xml's make any result
When I edit the rom 'ECU ID' with 'Hex edit' to a 53040010 on the 0x5002a adres, I'm able to open the rom with a 53040010 XMl (With a few adjustments in the XML-adresses of course), I'm able to modify the ROM. Afterwords I can change the ECU ID back to 53040007. When I open afterwords with ecuflash it recognizes a chechsum fault (which is normal I guess), Ecuflash is able to repair the fault but I'm sure there is a normal way without danger to get into the maps?
When I would aply this, and things go wrong, it could be a hilarious DIY story... so anyone? :D
backup - Kristof.hex
(1 MiB) Downloaded 762 times
student_scheire
Re: Checksum question
Postby martymonaro » Sat May 08, 2010 1:30 am
Here is the correct XML for you.
Marty
53040007.xml
(12.7 KiB) Downloaded 804 times
martymonaro
Postby student_scheire » Sat May 08, 2010 1:43 am
Finally a working Xml :d thanks dude!
student_scheire
