Unable to Flash newer 2010 STi ECU with ID:AZ1G701I
Postby v8bware » Wed May 05, 2010 10:05 pm
I have tuned quite a few 08, 09, and 2010 STI's and WRX. The early 2010 STi's are editable but mid year Subaru changed the ECU ID and you cannot flash the ECU. I can pull the rom and I have a definition that allows me to edit the rom but when i try to re-flash the ECU i get a "This area of the map is locked" error and the flash stops. The ECU ID from the later model year is AZ1G701I. Has anyone run into this issue or been able to flash a newer STi yet? Any help would be appreciated.
Neither ECU Edit or ECU Flash will flash this rom yet and i have not seen any updates for it yet.
Kert
v8bware
Re: Unable to Flash newer 2010 STi ECU with ID:AZ1G701I
Postby v8bware » Wed May 05, 2010 10:07 pm
Here is the Error I get with EcuFlash when flashing the rom back to the ECU along with the rom attached:
[10:06:25.578] EcuFlash Version 1.42.2595
[10:06:25.578] OS Version Windows XP
[10:06:25.578] Qt Version 4.5.0
[10:06:25.593] 56 memory models read.
[10:06:25.593] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[10:06:25.765] 343 ROM metadata models scanned.
[10:06:25.765] checksum module "subarudbw" loaded.
[10:06:25.765] checksum module "mitsucan" loaded.
[10:06:25.765] flashing tool "wrx02" loaded.
[10:06:25.765] flashing tool "wrx04" loaded.
[10:06:25.765] flashing tool "sti04" loaded.
[10:06:25.765] flashing tool "sti05" loaded.
[10:06:25.765] flashing tool "mitsukernel" loaded.
[10:06:25.765] flashing tool "mitsukernelocp" loaded.
[10:06:25.765] flashing tool "mitsubootloader" loaded.
[10:06:25.765] flashing tool "shbootmode" loaded.
[10:06:25.765] flashing tool "shaudmode" loaded.
[10:06:25.765] flashing tool "subarucan" loaded.
[10:06:25.781] flashing tool "mitsucan" loaded.
[10:06:31.343] AZ1G201I (313 tables) inheriting 32BITBASE (662 tables)
[10:06:31.390] AZ1G202I (0 tables) inheriting AZ1G201I (662 tables)
[10:06:31.453] 1048576 byte image read.
[10:06:33.078] J2534 API Version: 04.04
[10:06:33.078] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[10:06:33.078] Device Firmware Version: 1.10.2658
[10:06:35.875] kernel get version
[10:06:36.093] SSM2 init
[10:06:36.125] SSM2 ECU ID is 72 12 78 60 07
[10:06:36.125] Requesting Seed...
[10:06:36.125] Sending Key...
[10:06:37.000] kernel get version
[10:06:37.000] kernel version is : OpenECU Subaru SH7058 OCP CAN Kernel V1.06
[10:06:37.000] reading kernel comm buffer size
[10:06:37.000] comm buffer size set to 2048
[10:06:37.000] reading kernel flash buffer size
[10:06:37.015] flash buffer size set to 4096
[10:06:37.015] -- flashing image to ECU memory --
[10:06:37.406] -- comparing ECU flash memory pages to image file --
[10:06:37.406] seg start len ecu CRC32 img CRC32 same?
[10:06:37.421] FB01 00000000 00000FFC 3994EAD3 48256F5A NO
[10:06:37.421] FB01 00000FFE 00000002 41D912FF 41D912FF YES
[10:06:37.421] FB02 00001000 00001000 750D1713 750D1713 YES
[10:06:37.437] FB03 00002000 00001000 09D949A5 362C6FB2 NO
[10:06:37.437] FB04 00003000 00001000 81B364C9 304BCC1F NO
[10:06:37.453] FB05 00004000 00001000 ADC3A5D4 0FC6CCFA NO
[10:06:37.453] FB06 00005000 00001000 B68E5898 25B7356F NO
[10:06:37.468] FB07 00006000 00001000 BCAEC297 F2EE12F0 NO
[10:06:37.468] FB08 00007000 00001000 F8356F17 A9551E5F NO
[10:06:37.593] FB09 00008000 00018000 1683D220 26BACF35 NO
[10:06:37.765] FB10 00020000 00020000 F29F9674 0C161839 NO
[10:06:37.937] FB11 00040000 00020000 F84E397B 8F59A548 NO
[10:06:38.093] FB12 00060000 00020000 E9CFA81D 4CEFB6D0 NO
[10:06:38.265] FB13 00080000 00020000 8BC9EC07 113E1F06 NO
[10:06:38.437] FB14 000A0000 00020000 AA24EF3A 67AD7196 NO
[10:06:38.593] FB15 000C0000 00020000 E41BBC44 C901BB2A NO
[10:06:38.765] FB16 000E0000 00020000 916ABEE9 1A9E5A56 NO
[10:06:38.765] the image you are trying to flash contains changes to protected areas! exiting.
[10:06:38.765] interface close
[10:06:38.781] interface close
2010 STI MT Stock Map.hex
2010 Subaru STi rom
(1 MiB) Downloaded 992 times
v8bware
Postby radsdau » Thu May 06, 2010 4:49 pm
Thanks for that.
Can you reflash the factory ROM without changes? If not, then it's one for Colby to answer, for sure.
If you can, make a single change at a time to try and find which flash segment ECUFlash doesn't want to change.
Postby v8bware » Wed May 12, 2010 12:33 am
Nope. Was not able to flash the factory rom back still the same error.
Kert
v8bware
Postby radsdau » Wed May 12, 2010 3:02 pm
v8bware wrote:Nope. Was not able to flash the factory rom back still the same error.
Wow, that is curious. Definitely a Colby question.
Postby v8bware » Thu Dec 30, 2010 11:37 am
Was wondering if anyone has had this similar issue. I have been having my customers with the later model 2010 STi purchase a cobb unit. I would definately like to give them the option of going open source. Have not heard back on anything about this issue. I have posted up in this forum and also at epifansoft.com (EcuEdit) forums. Has no one had this issue?
v8bware
Postby Bruce Willis » Sun Jan 02, 2011 10:46 am
7058 CPU can be flash with SHboot mode
Bruce Willis
