Evo X ecuflash error/not working
Postby onboost » Fri Jun 26, 2009 5:49 pm
I have been running a modified rom for a couple of months and last night i was bored so i thought i would flash my old rom back and do some logging so i could see the difference between the 2. That flashed back fine and drove fine but logging didnt work.
So this morning i couldnt be bothered spending hours trying to get the logging going so i went to flash back my modified rom and it comes up with a ecuflash error. I cant test write, compare or do anything to my old rom or new rom. I cant even read the rom that is in there now.
The error comes up like this:
[11:42:14.055] 52370024 (149 tables) inheriting evo10base (173 tables)
[11:42:14.055] 52360018 (7 tables) inheriting 52370024 (181 tables)
[11:42:14.086] 1048576 byte image read.
[11:42:56.247] J2534 API Version: 04.04
[11:42:56.247] J2534 DLL Version: 0.50.2464 Jan 29 2009 10:58:58
[11:42:56.247] Device Firmware Version: 1.05.2463
[11:42:57.827] -- loading kernel --
[11:42:57.827] -- connecting to kernel --
[11:42:57.827] kernel get version
[11:42:58.201] ECU HW part number : 1860A933
[11:42:58.233] ECU SW part number : 1860A93300
[11:42:58.248] VIN : CZ4A-0000556
[11:42:58.248] -- unlocking ECU --
[11:42:58.248] starting session...
[11:42:58.295] requesting seed...
[11:42:58.591] interface close
[11:42:58.607] interface close
the orig rom is a 52360016. I have been running a 52360018 for a couple of months with no trouble. Please help!!!!
Do i have to use the X recovery mode in ecuflash to try get it back to normal.
onboost
Re: Evo X ecuflash error/not working
Postby leong1 » Mon Dec 28, 2009 12:30 am
hi bro ...
same problem with your ecu ..
but this is second ecu i have it now !!
same problem
[16:04:17.970] EcuFlash Version 1.42.2595
[16:04:17.970] OS Version Windows Vista
[16:04:17.970] Qt Version 4.5.0
[16:04:17.985] 56 memory models read.
[16:04:17.985] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[16:04:18.453] 344 ROM metadata models scanned.
[16:04:18.453] checksum module "subarudbw" loaded.
[16:04:18.453] checksum module "mitsucan" loaded.
[16:04:18.453] flashing tool "wrx02" loaded.
[16:04:18.453] flashing tool "wrx04" loaded.
[16:04:18.453] flashing tool "sti04" loaded.
[16:04:18.453] flashing tool "sti05" loaded.
[16:04:18.453] flashing tool "mitsukernel" loaded.
[16:04:18.453] flashing tool "mitsukernelocp" loaded.
[16:04:18.453] flashing tool "mitsubootloader" loaded.
[16:04:18.453] flashing tool "shbootmode" loaded.
[16:04:18.453] flashing tool "shaudmode" loaded.
[16:04:18.453] flashing tool "subarucan" loaded.
[16:04:18.453] flashing tool "mitsucan" loaded.
[16:04:29.919] J2534 API Version: 04.04
[16:04:29.919] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[16:04:29.919] Device Firmware Version: 1.07.2597
[16:04:34.402] -- loading kernel --
[16:04:34.402] -- connecting to kernel --
[16:04:34.402] kernel get version
[16:04:34.746] ECU HW part number : 1860A933
[16:04:34.761] ECU SW part number : 1860A93300
[16:04:34.792] VIN : CZ4A-0005727
[16:04:34.792] -- unlocking ECU --
[16:04:34.792] starting session...
[16:04:35.058] requesting seed...
[16:04:35.073] sending key...
[16:04:35.916] interface close
[16:04:35.978] interface close
[16:05:19.784] J2534 API Version: 04.04
[16:05:19.784] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[16:05:19.784] Device Firmware Version: 1.07.2597
[16:05:21.926] -- loading kernel --
[16:05:21.926] -- connecting to kernel --
[16:05:21.926] kernel get version
[16:05:22.051] ECU HW part number : 1860A933
[16:05:22.067] ECU SW part number : 1860A93300
[16:05:22.098] -- unlocking ECU --
[16:05:22.098] starting session...
[16:05:22.098] requesting seed...
[16:05:22.114] sending key...
[16:05:22.956] interface close
[16:05:22.972] interface close
[16:05:47.017] J2534 API Version: 04.04
[16:05:47.017] J2534 DLL Version: 0.50.2598 Jun 26 2009 15:02:29
[16:05:47.017] Device Firmware Version: 1.07.2597
[16:05:52.375] -- loading kernel --
[16:05:52.375] -- connecting to kernel --
[16:05:52.375] kernel get version
[16:05:52.547] ECU HW part number : 1860A933
[16:05:52.578] ECU SW part number : 1860A93300
[16:05:52.593] -- unlocking ECU --
[16:05:52.593] starting session...
[16:05:52.593] requesting seed...
[16:05:52.609] sending key...
[16:05:53.451] interface close
[16:05:53.467] interface close
leong1
Postby NPS » Sun Dec 25, 2011 12:23 pm
what was the problem how did you solve it ?
NPS
Postby NPS » Sun Dec 25, 2011 11:38 pm
have the rom 52360016 on Evo X same problem cant read HELP !!!
put extra battary for the voltage, check drivers for the cable tried few ecuflash models still same
NPS
Users browsing this forum: No registered users and 58 guests
