Problem reading ecu!!!
Postby KenYong3671 » Mon Nov 19, 2007 10:08 am
Hi there,
I have been struggle with ECUFLASh since the release of version 1.30 till now 1.34. Whenever i tried to read the ecu i would get the following message: (Please Help)
"[02:03:46.883] Version 1.34.1435
[02:03:46.893] 11 memory models read.
[02:03:46.913] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[02:03:48.825] 226 ROM metadata models scanned.
[02:03:48.825] checksum module "subarudbw" loaded.
[02:03:48.825] flashing tool "wrx02" loaded.
[02:03:48.825] flashing tool "wrx04" loaded.
[02:03:48.825] flashing tool "sti04" loaded.
[02:03:48.825] flashing tool "sti05" loaded.
[02:03:48.825] flashing tool "mitsukernel" loaded.
[02:03:48.825] flashing tool "mitsukernelocp" loaded.
[02:03:48.825] flashing tool "shbootmode" loaded.
[02:04:23.445] Using interface OpenPort 1.3 Mitsubishi TX14sjYg63faf4c900000000000000000000000000000000
[02:04:23.445] interface close
[02:04:23.455] unable to connect to vehicle interface.
[02:04:23.455] interface close"
However, if i switch to 1.29 or earlier version. i have no problem at all, even wtih the latest driver that provide by the version 1.3X.
KenYong3671
Re: Problem reading ecu!!!
Postby BoxerFan » Sat Jan 19, 2008 5:52 am
I have exactly the same problem as above. Only 1.29 works for me.
Any help appreciated.
BoxerFan
Postby rdtech » Sat Jan 19, 2008 9:28 am
Have you tried uninstalling everything including the tactrix cable and ver1.34
Then install the ver 1.34 without the tactrix cable connected. When its finished installing, then hook up the tactrix cable. It should start to install the drivers for the cable based on your system.
That worked for me. I use to have the same problems before.
:lol:
rdtech
