B9 Tribeca is support
Postby evoX » Wed Oct 31, 2007 12:11 pm
I have tried to read the ROM from a B9 Tribeca with the latest version of ecuflash, but it does not work. I have connected the green connectors which put the car in test mode, but it cannot read the ecu.
Are other connectors which needs to be connected ?
Does ecuflash support the B9 Tribeca?
evoX
Re: B9 Tribeca is support
Postby Jon [in CT] » Wed Oct 31, 2007 1:00 pm
evoX wrote:Does ecuflash support the B9 Tribeca?
It should work with the 2006 Tribeca, but probably not with the 2007+ model years, which I believe use CAN to read/reflash.
Postby evoX » Wed Oct 31, 2007 1:11 pm
thanks, I tried on a 2006 Tribeca
evoX
Hi
Postby christian_piasini » Mon Feb 04, 2008 12:57 am
Did you have some pictures of the ecu installed in?
I looking for it.
Regards
R&D Piasinoiengineering
Postby evoX » Mon Feb 04, 2008 5:42 am
Hi,
No I don't have :(
evoX
