Can't write to ECU program voltage out of range
Postby mxturboracer86 » Mon Apr 09, 2007 2:20 pm
As the title says i am trying to re-flash my friends 02 wrx and i can send the stock map back on but when you try to flash another map on it gives the error of:
program voltage 4.24v
program voltage out of range!
both the test connector and flash block are connected
mxturboracer86
Postby mxturboracer86 » Mon Apr 09, 2007 7:18 pm
anyone ever seen this b4?
mxturboracer86
Postby Freon » Tue Apr 10, 2007 8:16 am
You might get a multimeter and check the voltage you're getting across the flash connector. You should get close to 12v.
Postby Hyper » Tue Apr 10, 2007 10:10 am
I have the same problem
I searched for it, and it appears that you might need to wire 12v to one of the OBD II wires
Hyper
Postby mxturboracer86 » Tue Apr 10, 2007 6:37 pm
do you kno which wire on the OBDII cord...anyway to just run more power to the jumper?
mxturboracer86
Postby Freon » Tue Apr 10, 2007 6:47 pm
Have you checked the voltage yet with a multimeter? With one probe in each side of the white connector you should read either about +12v or about -12v. I'm not sure off the top of my head if the key needs to be in, turned, or not so you might test putting the key in "run" (but don't start) to be sure.
Postby ride5000 » Sun Apr 22, 2007 9:59 am
solved the same problem today.
writeup here:
http://forums.openecu.org/viewtopic.php?p=13952#13952
hth
ken
ride5000
