Can not reflash/read/do any damn thing with my ecu.
Postby knome » Wed Mar 28, 2007 6:23 pm
I can not access my ECU period. I've tried every single application imaginably including ECUTECK and i don't get any responses back from the ecu. I just says denyso_bootload_cmd over and over again until it times out.
Please help, i don't car if i salvage the map, i just want the thing nuked. I'm about to rip it out and blow it up.
knome
Postby NSFW » Wed Mar 28, 2007 8:34 pm
What kind of car?
Are you familiar with the diagnostic mode connectors?
Does the car still run? (i.e. are you worried that the ECU is bricked?)
NSFW
Postby knome » Wed Mar 28, 2007 8:58 pm
I have a 02 wrx auto wagon. Yes i am familiar with the connectors. This happened when i was trying to get my car ECUTECK tuned. The tuner tried everything including openecu.
Yes the car still runs just the port is unresponsive.
knome
Postby Freon » Thu Mar 29, 2007 3:28 am
Did you just post this on NASIOC as well? And you just put in a turbo timer? I wouldn't be surprised if you somehow cut or spliced a wrong wire somewhere.
Postby knome » Thu Mar 29, 2007 3:10 pm
Yea i'm posting everywhere. And i already took out the wires. still doesn't work.
knome
Postby gethin » Thu Mar 29, 2007 4:20 pm
when you close the green connectors, and key on, do the fans cycle on and off?
gethin
Postby knome » Thu Mar 29, 2007 11:49 pm
yea. I took it to two dealers today and they don't know what is going on.
knome
Postby Freon » Fri Mar 30, 2007 4:44 am
Can you log?
Postby knome » Fri Mar 30, 2007 11:02 pm
yea i can log.
Ecu explorer gives this error.
Kernel flash disabled.
knome
Postby swifty » Sat Mar 31, 2007 1:36 pm
Is the ecu a replacement such as gems or other non-denso ecu ?
swifty
Postby knome » Sat Mar 31, 2007 3:10 pm
no its a stock ecu.
knome
Postby knome » Tue Apr 03, 2007 1:54 pm
Well i just got back from subaru and they say the wiring is perfectly fine. They say the problem is the flash that was put on it is superseding all attempts to re-flash and because of that is locking me out (having to do with the map starting with X). The mechanic said that there is nothing that i can do to remove it other than get in touch with the map maker and see if he can get it off.
So i need a new ecu, does anyone know if the 2002 wrx manual ecu will work in an automatic version?
knome
Postby Jon [in CT] » Tue Apr 03, 2007 2:33 pm
knome wrote:So i need a new ecu, does anyone know if the 2002 wrx manual ecu will work in an automatic version?
It will work.
