ecuflash 1.30 with EDM WRX06 ?
Postby ponos808 » Sat Apr 14, 2007 3:30 am
ok, thanks!!!
i"ve searched through all the car to find this another set of passengers side connectors....have found them, proceed with flashing successfully, and only today read your post $-) but thank you anyway...
that's because Colby assuring me earlier (december) that no additional connections have to be made to flash my car
OK, THANKS TO ALL !!!!
ponos808
Postby korhan » Sat Jul 07, 2007 3:00 am
in edm 06 wrx there are only green connectors and when you connect them car goes to diagonistc mode and you can flash it:)
as mercgod said you dont need to connect them for loging.
i also try to flash to edm 06 wrx. i took the map with enginuity and then inherit but i can not flash because its a friend car and i got afraid to cook the ecu.
also there is a problem like this. i know that the 06 edm wrx has a 440cc injektors but i see 550s in the map. what is the real size? is it because of the inheriting or is it really 550s?
next week i am going to try to flash if i hit it i can tell you...
korhan
Postby hmanxx » Wed Jul 11, 2007 11:30 pm
wrx 06 EDM spec..is 550cc..not 420cc. i have done datalogging on a wrx06 with VF30, airflow at 250 gram/sec yet injector duty cycle at 86% ++ on stock car setting.
If 420cc, sorry..the injector duty cycle will hit 100%
hmanxx
550 cc
Postby ponos808 » Fri Jul 13, 2007 4:33 am
korhan wrote:in edm 06 wrx there are only green connectors and when you connect them car goes to diagonistc mode and you can flash it:)
I do not think, that it is 420 cc in EDM 06//// I'm successfully flash an boost upped maps and not get LEAN on 1.3 relative boost....but DO NOT TRY TO REPEAT IT if you aren't certanly sure what are you doing
ponos808
Postby hmanxx » Sat Jul 14, 2007 9:46 am
thanks for your concern, Yes..i know what I am doing
hmanxx
