merchgod wrote:You can flash without any table definitions in Ecuflash. The flash method just has to be correct. When Ecuflash doesn't recognize/support a rom, it asks you if you want to inherit another rom's definitions. When you do this, it is likely that the definitions will be wrong if you were editing it with Ecuflash. But this will not affect flashing unless you edit with Ecuflash and then SAVE.
merchgod wrote:Yes
merchgod wrote:You need to connect the green test mode connectors to read or flash. They are located above the driver's side footwell.
