Trying to get OpenECU HW working with Tari software
Postby twg » Thu Jun 02, 2005 9:15 am
I just got my OpenECU HW...
I installed the FTDI 232BM drivers.. the VCP drivers...
I then installed the Tari DL1...
I am using COM5..
When I start Tari, it says that it cannot communicate with the ECU...
I tried the free version of VE1, but it only supports up to COM3, so no go..
Any suggestions ?
twg
Postby west_minist » Thu Jun 02, 2005 5:10 pm
Change the driver com port in computer management console.
Postby twg » Thu Jun 02, 2005 6:47 pm
not sure why it didn't work on COM5, but once I freed up COM3, it worked..
free version of VE1 didn't work still though...
twg
Postby west_minist » Thu Jun 02, 2005 6:50 pm
once the program call for a port, it will not work on another.
freeing up the com3 with work as you stated.
Postby calvinc » Thu Jun 02, 2005 10:42 pm
twg...
did you manage to get the software working yet? if not send me an email.
www.tari.co.za
Postby west_minist » Fri Jun 03, 2005 2:26 am
But then again, the Tari gives you com1 to com9.
So just select the port in the future and you are good to go. :)
Postby higB_0x05 » Fri Jun 03, 2005 12:49 pm
I cant get your software to work with this board:
http://www.andywhittaker.com/ecu/obdii_hardware.htm
:( should it?
higB_0x05
Postby west_minist » Fri Jun 10, 2005 11:13 am
I am now in the same boat. i cannot even get the driver install.
Anyone know which file I need to download from FTDI?
Postby cboles » Fri Jun 10, 2005 6:15 pm
you need the driver for the FT232BM
Postby west_minist » Fri Jun 10, 2005 6:19 pm
I realise that when the first drivers failed.
It took awhile to get them install, but there are working great.
My only problem right now is logging. The Tari software are not showing the right results and the sample code on the net does not have the AFR reading.
Thanks cboles
Postby realwomble » Sat Jun 11, 2005 10:55 am
Look at the other free logger in the dataloggin development section - that will read AFR, and there is source code.
realwomble
Postby west_minist » Sat Jun 11, 2005 11:36 am
It wouldn't work.
Mike own is the only one that read afr.
Postby Evo4Mad » Thu Jun 01, 2006 1:11 am
I have tried installing a number of drivers with OpenPort 1.3M, but cant get the Virtual ComPort to appear anywhere. not in the device manager.
Postby grippgoat » Wed Sep 27, 2006 8:22 am
Evo4Mad wrote:I have tried installing a number of drivers with OpenPort 1.3M, but cant get the Virtual ComPort to appear anywhere. not in the device manager.
I think I'm having the same problem with my OpenPort 1.3 for Subaru DBW.
-Mike
grippgoat
Postby johsti » Fri Sep 29, 2006 8:04 am
I'm having a poblem with a nonDBW subaru.
johsti
Users browsing this forum: No registered users and 38 guests
