AUD-Support of ECUflash ?
Postby Jochen_145 » Sun Sep 30, 2012 12:45 am
Hey,
I found here in this forum and in other that ECUFlash should be able to support AUD-port readout (bit-bang-mode ?!)
with a spezial interface..
What´s about this ?
Is the support implementated in all ECUFlash versions or only in "special" ones ?
What kind of interface is needes, do someone got a wireing of it ?
How to activate the AUD-reading in ECUFlash and is it possible to scale the readout size ?
If ECUFlash is able to support AUD-readout, I thing it will be a big advantage to the SW.
Every hints to "easy-AUD-solutions" etc. are wellcome :!:
Jochen
Jochen_145
Re: AUD-Support of ECUflash ?
Postby Bruce Willis » Tue Oct 09, 2012 8:44 pm
I am interesting too
Bruce Willis
Postby Jochen_145 » Sun Oct 14, 2012 2:11 am
found that bitbang-mode of FTDI chip makes it work as a 8bit bi directional bus.
So IMO it will work like the arduino- or propellor board solutions explained on active board
Jochen_145
Postby Sasha_A80 » Sun Oct 14, 2012 6:10 am
AUD mode is disabled at Subaru Denso ecu's.
That means this backdoor is locked.
Anyway you are welcome...
Sasha_A80
Postby Jochen_145 » Sun Oct 14, 2012 8:31 am
Sasha_A80 wrote:AUD mode is disabled at Subaru Denso ecu's.
Don´t know about that..
PIASINI and some other read via AUD the Subaru Denso ECUs.
Even china clone reads AUD, but not stable so you get a read-out wiht some crap values and so bad checksum
Maybe this is only on some special ECUs ?
Jochen_145
Postby Sasha_A80 » Sun Oct 14, 2012 8:55 am
Jochen_145 wrote:Maybe this is only on some special ECUs ?
It may be.
I personnally have not seen completely unlocked yet. Just analyze the code already uploaded.
Sasha_A80
Postby Jochen_145 » Sun Oct 14, 2012 9:00 am
Piasini needs a bridge between a connection, with I just know by picture and GND.
Without this bridge, the read-out will not work.
Maybe this "short circle" the locked backdoor ?
Jochen_145
Postby Bruce Willis » Sun Oct 14, 2012 7:41 pm
У тебя осталась картинка ЭБУ, который был залочен? Мне еще не один блок не попадался залоченный.
Bruce Willis
Postby Sasha_A80 » Sun Oct 14, 2012 9:11 pm
Do you have any pictures of the ecu locked?
I have not seen any locked yet.
MY04 JDM Legacy dual AVCS ecu. I suspect ADM dual AVCS versions use the same code.
Just analize or download the code into any SH7055 ecu.
Have fun.
AUD readable after being enabled inside the code.
A2ZJ600B_A2100F_2F04785006.bin
ROM image
(512 KiB) Downloaded 445 times
JDM Legacy GT dual AVCS ecu
Sasha_A80
