Does anyone know a good source for init connectors?
Postby cboles » Sun Jan 30, 2005 7:13 pm
I'm looking to find the 2 and 4 pin connectors used on the 02-05 MY WRXs for initialization to reflash. Like the ones pictured on page 5 of this
http://www.accessecu.com/support/ap-usersguide-wrx.pdf
Anyone know where to buy these?
Postby fabrik8 » Mon May 30, 2005 7:58 am
I know this has been a few months since the original post, but I may be able to help you if you can track down some kind of logo on the connector itself. Are there any markings on it? I tracked down all the Honda ECU connectors in the past, which was no easy task, and these look a bit more generic. The 2002 connector almost looks like a standard speaker connector that Molex/Waldom makes..
fabrik8
Postby cboles » Mon May 30, 2005 10:12 am
OK. I found the 2002 connector. It is an AMP 172131-5 housing and a AMP 170349-1 terminal. Here are the drawing(s):
JPN_CD_170349_A1.pdf
2002 WRX programming connector terminal
(25.66 KiB) Downloaded 851 times
ENG_CD_172131_D-1.pdf
2002 WRX programming connector housing
(30.63 KiB) Downloaded 848 times
Postby cboles » Mon May 30, 2005 10:49 am
The 2004 connector may be made by someone else. It is a 6 position (2x3) housing with a 0.200" x 0.150" pin pitch. Each pin is a 0.088"x0.024" cross-section blade. The back of the housing has a very small diamond shaped logo with what appears to be a Kanji character in it. The character looks somewhat like this (ignore the *'s - ASCII art is difficult with non-fixed fonts)
|_|_|
(or perhaps it is a sideways "EH" with a line through it - too small to tell, really)
Also on the back is "Y3".
Postby fabrik8 » Mon May 30, 2005 11:00 am
OOOohhhhh I know that logo.. hold on.. Let me check something out..
As soon as I thought "diamond" I thought I had it.. I was thinking JAE or Sumitomo..
I'm going to poke around under the dash..
I just found what I think is a Yazaki connector also, but that's of no importance to what we want.. Sooo many connectors under there, good lord..
fabrik8
Postby fabrik8 » Mon May 30, 2005 11:49 am
Well, I have no idea what to tell you about the Kanji symbol, mine just has the diamond, which looks like the Sumitomo logo, and says Y7 on it. There is nothing inside the diamond at all..
Look familiar???? :wink:
*edit*
I've found a distributor.. they're really hard to find, but apparently Kawasaki uses them for something in their ATV or Motorcycles..
fabrik8
Postby cboles » Mon May 30, 2005 5:21 pm
Nice searching! The right hand part is definitely what we need to plug into the car. The Sumitomo diamond logos don't really match the diamond on mine, but the part is definitely a match.
Postby fabrik8 » Mon May 30, 2005 6:32 pm
The diamond on mine matches the logo, the lines that make up the logo are just skinny. What is the purpose of the init connector anyway, is it like the diagnostic jumper for older OBD generations?
fabrik8
Postby crazymikie » Mon May 30, 2005 8:38 pm
This connector is used to bring 12V over I beleive. Putting the two green connectors under the dash together puts the ECU in diagnostic mode. I know this connector has to do with the 12V supply since if you don't connect it, you will get a 'low voltage' error with the AccessPort.
Mike
crazymikie
Here is the PDF of the 2004 WRX programming connector
Postby cboles » Tue Jun 28, 2005 11:04 am
The connector is P/N M(6090-1149)
The pins are P/N M(8230-4282)
e_hm_e.pdf
(818.47 KiB) Downloaded 926 times
Postby qoncept » Wed Oct 26, 2005 10:33 am
Colby, do you know where we can get these? I think I'm about to just say screw it and buy a different male and female connector and solder it on.. Or, better yet, just complete the circuit with a switch.
Postby ahains » Wed Oct 26, 2005 10:59 am
qoncept wrote:Colby, do you know where we can get these? I think I'm about to just say screw it and buy a different male and female connector and solder it on.. Or, better yet, just complete the circuit with a switch.
Many of us just use a simple piece of wire to jumper it, like pictured here:
http://www.dvihdmicables.com/WRX/ECUF-How-To.htm
There is no harm in leaving it connected full time. This is what I and most folks do.
You only connect the green connectors when you are flashing, but the flash block can stay connected.
-Adrian
ahains
Postby qoncept » Wed Oct 26, 2005 11:07 am
Double post
Postby qoncept » Wed Oct 26, 2005 11:08 am
Oh! I thought it would drain my battery. I did jumper it with wire last night, and I was looking for a way around it because it was a nightmare to do in the dark (and I don't imagine it's much easier with light). Now I just need a more convenient way to connect the green ones.. :)
As an aside, I was really surprised with how much battery I drained having it connected just long enough to dump my ECU.
Postby cboles » Wed Oct 26, 2005 12:16 pm
I have sources for these connectors - the problem is that I can't get them in the smaller quantities we need (e.g. < 10k). I'm still working on it though. I leave this connected all of the time in all of my cars. This does not drain the battery. Leaving an OpenPort plugged in *will* drain your battery eventually, however.
