ASTRA-G ISO14230 PERIODIC TX AUTO ANSWER NOT OK. HELP!
Postby dock » Sat Aug 30, 2008 4:46 pm
I am using odb2 interface with elm and several common commands are working pretty fine, however when i try to use the Periodic Transmission mode, auto repeat answer, the ECU reply with the first answer ok but stop and do not enter in continuous answer mode.
I send the command 10 82
it answer 50 82
.. and stop.
It should after 50 82, continuously send the last answer repeteadly.
I´m using the following manual
http://www.alfa145.co.uk/obd/14230-2s.pdf
page C4
Is something wrong?
Dock
dock
Re: ASTRA-G ISO14230 PERIODIC TX AUTO ANSWER NOT OK. HELP!
Postby Andrey » Fri Feb 27, 2009 11:52 pm
I don't see never that Tech2 sends this command.
Andrey
