SMP-safe drivers?
SMP-safe drivers?
Postby LGT-3-6 » Fri Apr 04, 2008 5:01 pm
Anyone have a clue as to the effort involved? I've never done kernel debugging on XP, but I can give it a go if someone gives me a hand.
LGT-3-6
Postby Jon [in CT] » Sat Apr 05, 2008 8:06 am
Drivers for what? Maybe the problem is in your application. What are you trying to run?
Postby LGT-3-6 » Sat Apr 05, 2008 10:15 am
Jon [in CT] wrote:Drivers for what? Maybe the problem is in your application. What are you trying to run?
Drivers for the OpenPort 1.3
It is definitely not an application problem. Applications can't hardlock the kernel no matter how hard they try.
LGT-3-6
Postby Jon [in CT] » Sat Apr 05, 2008 4:50 pm
Again, what application are you running?
Postby LGT-3-6 » Sat Apr 05, 2008 5:28 pm
street tuner.
LGT-3-6
Postby LGT-3-6 » Sat Apr 05, 2008 9:32 pm
And of course, this did not matter.
I updated the driver pack with the latest FTDI drivers, which is WHQL certified and SMP safe. It would be nice if someone with a bench-flasher would double check that flashing works properly, attached.
3-13-2008 FTDI.zip
(795.73 KiB) Downloaded 295 times
LGT-3-6
