Advanced Qu: Requesting other pins?
The mut mode on the standalone logger, its requesting the K-Line on pin# 8 if I remember correctly. Is there any way to make a simular request on a diffrent pin like for example if you had a second ECU in the car and wired it into obd pin# 15 and had all the supplementary wiring done so that it works. Is there any way to make requests on pin#8 and then change the mode to make requests on pin 15 also so in theory combining the logs of two ecu's into one real time log?
Serious Inquiry and looking for assistance please...
