Fast-poll logging with type=ssmk ?
Postby Jochen_145 » Thu Nov 15, 2012 3:30 am
Hey,
is it possible to activate fast-poll modus of Subaru K-Line stand-alone logging ?
Is it allready implementated or does it need software chances ?
If it is allready possible to use, how to activate it ?
BR Jochen
Jochen_145
Re: Fast-poll logging with type=ssmk ?
Postby Tremayne_XT » Wed Jan 23, 2013 8:34 pm
I too would like an update on this query. Logging to the laptop either through romraider or ecuedit is significantly faster than logging to SD card, even when logging more parameters.
Is there some kind of command line etc to add to the logcfg.txt file to enable this on the SD card or is it a hardware / firmware issue with the tactrix that limits its functionality in this respect.
Tremayne
Tremayne_XT
Postby Jochen_145 » Sun Mar 10, 2013 8:12 am
*bump*
any progress in this ?
Is it possible or is it planed to have fast-poll in stand-alone logger, like RomRaider has allready ?
Jochen
Jochen_145
Postby Jochen_145 » Sun Mar 17, 2013 1:48 am
Just to give some info, but I think your allready know:
there are two ways in inprouving sampling speed. First you can chance the boudrate of SSM-II protocoll from 4800baud to 10400. This will give about 2 times more sample rate.
The other way is to use continous push mode, with in RomRaider is called "Fast-poll"
Some info you will finde on Subaru Diesel Crew side:
http://subdiesel.wordpress.com/2011/07/ ... 0400-baud/
(I think you allready found :wink: )
Jochen_145
Postby impulse » Fri Jun 06, 2014 6:37 am
Was this ever implemented? It should be as simple as flipping one bit:
http://www.romraider.com/RomRaider/SsmProtocol
PP == 0×00 (single response), 0×01 (respond until interrupted)
impulse
