OP Stand Alone Logging Help
Hi All,
Just got my firmware updated and I am ready to log but am a bit confused by the instructions for the .txt used for the logging parameters. I have basic knowledge of php and a good working knowledge of html but this is above my head.
Would it be possible for someone to throw together a text file for the following parameters logging only when the rear defog button is pushed? I am going to log off the narrowband at the moment until I get my LC1.
My car is an 08 WRX USDM MT. ECU is AZ1E401A
A/F Correction(%)
A/F Learning(%)
A/F Sensor #1(AFR)
Engine Speed (RPM) [RR]
Engine Load (1 byte) (g/rev) [RR]
Fine Learning Knock Correction (degrees)
Feedback Knock Correction(degrees)
IAM
Ignition Total Timing
Injector Duty Cycle(%)
Manifold Relative Pressure(corrected)(PSI)
Mass Airflow (g/s)
Primary Wastegate Duty Cycle(%)
Throttle Opening Angle(%)
Vehicle Speed (mph)
Thanks in advance,
Curt
A/F Correction(%)
A/F Learning(%)
A/F Sensor #1(AFR)
IAM
Mass Airflow (g/s)
Vehicle Speed (mph)
Thanks in advance,
Curt
