no have logXXXX.csv file
Postby toeng » Sun Nov 07, 2010 8:26 pm
Hi,
First time I try logging ECU, It do not have any logXXXX.csv. I donot see any error statement in logcfg.out file.
May someone tell me that what is error?
Thank you in advance.
toeng
Re: no have logXXXX.csv file
Postby toeng » Sun Nov 07, 2010 8:29 pm
This is logcfg.out file
(Why I can not upload fileX
003: type=obd
: name[type,8] value[obd,0,0.000000]
004: protocolid=6 ; ISO15765 - the only protocol supported at the moment
: name[protocolid,9] value[6,6,6.000000]
005: ; this is a mode $01 parameter
006: ; it should work on any CAN ECU
007: ;100/255 = 0.392156863
008: paramname=load
: name[paramname,16] value[load,0,0.000000]
009: mode=0x01
: name[mode,73] value[0x01,1,0.000000]
010: paramid=0x04
: name[paramid,17] value[0x04,4,0.000000]
011: ;databits=8 Default
012: scalingrpn=x,0.392156863,*
: name[scalingrpn,18] value[x,0.392156863,*,0,0.000000]
013: paramname=RPM
: name[paramname,16] value[RPM,0,0.000000]
014: mode=0x01
015: paramid=0x0C
: name[paramid,17] value[0x0C,12,0.000000]
016: databits=16
: name[databits,22] value[16,16,16.000000]
017: scalingrpn=x,0.25,*
: name[scalingrpn,18] value[x,0.25,*,0,0.000000]
018: paramname=Speed
: name[paramname,16] value[Speed,0,0.000000]
019: mode=0x01
020: paramid=0x0D
: name[paramid,17] value[0x0D,13,0.000000]
021: ;databits=8
022: scalingrpn=x
: name[scalingrpn,18] value[x,0,0.000000]
023: paramname=CoolTemp
: name[paramname,16] value[CoolTemp,0,0.000000]
024: mode=0x01
025: paramid=0x05
: name[paramid,17] value[0x05,5,0.000000]
026: databits=16
027: scalingrpn=x,40,-
: name[scalingrpn,18] value[x,40,-,0,0.000000]
028: ;-------------triggers---------------
029: conditionrpn=RPM,500,>
: name[conditionrpn,48] value[RPM,500,>,0,0.000000]
030: action=start
: name[action,49] value[start,0,0.000000]
031: conditionrpn=RPM,500,<
: name[conditionrpn,48] value[RPM,500,<,0,0.000000]
032: action=stop
: name[action,49] value[stop,0,0.000000]
--- log config dump ---
firmware version is: 1.11.3137
the following general options are set:
* interpolate missing samples
* zero sample count at start of each file
channel type: obd
protocol id: 6
baud: 500000
mode23txaddrwidth: 3
mode23txlenwidth: 1
mode23rxaddrwidth: 2
param name: load
param id: 0x00000004
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
mode: 0x01
scaling: x,0.392157,*
param name: RPM
param id: 0x0000000C
read width: 2 bytes
data width: 16 bits
data offset: 0 bits
float: 0
mode: 0x01
scaling: x,0.250000,*
param name: Speed
param id: 0x0000000D
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
mode: 0x01
scaling: x
param name: CoolTemp
param id: 0x00000005
read width: 2 bytes
data width: 16 bits
data offset: 0 bits
float: 0
mode: 0x01
scaling: x,40.000000,-
trigger action: start condition: RPM,500.000000,>
trigger action: stop condition: RPM,500.000000,<
--- storage info ---
log channels: 1
log parameters: 4
log stringlist: 46 chars
log floatlist: 4 floats
4 obd requests per cycle (worst case), taking 50000us per cycle (45000us is fastest possible)
logging interval will be 50000us
toeng
Postby mohammadov » Mon Nov 08, 2010 1:06 pm
can u post ur logcfg.txt ?
mohammadov
Postby toeng » Mon Nov 08, 2010 8:12 pm
This is logcfg.txt .
;----------------obd ----------------
; log channel settings
type=obd
paramname=load
mode=0x01
paramid=0x04
;databits=8 Default
paramname=RPM
mode=0x01
paramid=0x0C
databits=16
scalingrpn=x,0.25,*
paramname=Speed
mode=0x01
paramid=0x0D
;databits=8
scalingrpn=x
paramname=CoolTemp
mode=0x01
paramid=0x05
databits=16
scalingrpn=x,40,-
action=start
action=stop
toeng
