Online Openport Config tool Beta
Postby enthusiast » Sun Dec 06, 2009 4:12 pm
Based on the work by freakin (thank you!) I created a online configuration file generator for the Open Port 2.0 microSD logger.
Pros
    logger.xml and ecudefs.xml do not need to be installed on your computer as the server parses it online
    No software to install on your PC.
    Tested to work on IE8 and FF3.x
    ECU ID dropdown is searchable (ie: your ECU ID is A2WC510N you can enter 510N in the drop down and find it)
    Primary and extended parameters are searchable in the generated table
    Uses OS web frameworks
Cons
    I have not implemented parameters with dependencies (computed parameters)
    I am only using Imperial measurements (I will put the others in soon)
    I have only defogger switch setup for now (more coming)
    Have to cut and paste into editor to save configuration file (temporary)
Future Releases will include
    Sessions (you need to allow cookies)
    Generate preset configurations (Airboy, MRP/MAP, etc
    Editable fields (make your parameters names shorter before you make your config file).
    Save configurations to computer
Anyone interested in helping me test it out? I still need to iron out some bugs but for the most part it works. You need to have your OP2 firmware updated.
Read how to do it here: viewtopic.php?f=57&t=4319
PM me for details. I don't want to open it up yet until I make sure the code I have does not crush my server. :D
Edit:
20091207: Added drop down image reference
enthusiast
Re: Online Openport Config tool Beta
Postby enthusiast » Mon Dec 07, 2009 10:34 pm
ladams00 can you PM me your email? I tried to send you a PM back and it kept telling me no recipient :oops: Your PM address was the only one that did that.
thanks
enthusiast
Postby freakin » Tue Dec 08, 2009 11:36 am
output from the tool matches my output so all that should be good :D bar the length problems with the strings.
my $0.02
  • When you click generate cfg file it does a document.write to to the child window which appends so you end up with multiple configs on one page.
  • The column headers look like links that should sort but they dont.
  • The search box is neat but confusing because you can filter the list and (de)select the one you do(nt) want and click generate, but it says nothing is selected or you only get that one.
if you need a hand with anything give me a shout.
freakin
Postby enthusiast » Tue Dec 08, 2009 11:58 am
I have column sorting turned off for now. You are right about the child window being appended to. I have been thinking of just using jqueryui's modal window to present the information.
I am having a hard time with getting ZeroClipboard to work. This will allow to just download the file without generated a file on the server. Have you worked with it?
I will look into the filter part tonight.
thanks for the feedback.
enthusiast
Postby enthusiast » Sat Dec 26, 2009 9:23 pm
freakin wrote:output from the tool matches my output so all that should be good :D bar the length problems with the strings.
my $0.02
Fixed this one.
enthusiast
Postby RacnJsn95 » Fri Mar 26, 2010 8:29 am
Is this live yet?
RacnJsn95
Postby enthusiast » Thu Apr 01, 2010 9:39 pm
I am not getting email from this site.
The site is live.
http://www.verticaltier.net/configtool/logger.php
enthusiast
Postby curt5446 » Fri Jan 21, 2011 3:33 pm
I know this thread is old but it would be cool to see some updates to this. I need a config file for an AZ1E401A
curt5446
