SUBARU ECU IDs
I thought posting this will be helpful,u can know ur ECU/ECUID/map size/year/model from this table,u can check if definitions exists for ur ecu id.
Currently this is for JDM ECUS,i will be posting USDM and EDM soon.
----ECU--------ECUID-----size--JDM
A2PG420A 4B04535107 1024 JDM 07 LG
A2SB000A 6204504007 1024 JDM 08 LG
A2SB000Y 6202504007 1024 JDM 08 OB
A2TB100A 5204504007 1024 JDM 07 LG
A2TB100K 5204784007 1024 JDM 07 LG
A2TB100V 5104504007 1024 JDM 08 IM
A2TB100Y 52045C0007 1024 JDM 07 LG
A2TB100Z 520478C007 1024 JDM 07 LG
A2UG000B 4B04585007 1024 JDM 06 LG
A2UH000A 4B04505107 1024 JDM 06 LG
A2UI000K 4B04785207 1024 JDM 06 LG
A2WC011E 3B02594216 512 JDM 04 FR
A2WD000A 3C04504006 512 JDM 03 LG
A2WD001A 3C04504106 512 JDM 03 LG
A2WD010A 3C04504216 512 JDM 04 LG
A2WD010B 3C04784216 512 JDM 04 LG
A2WD012A 3C04504316 512 JDM 05 LG
A2WD012B 3C04784316 512 JDM 05 LG
A2WD012G 3C54404316 512 JDM 04 LG
A2ZJ601A 2F04505106 512 JDM 04 LG
A2ZJ800A 2F04505206 512 JDM 04 LG
A2ZJC00B 2F04785206 512 JDM 04 LG
A2ZJD00A 2F04505406 512 JDM 04 LG
A2ZJD00B 2F04785306 512 JDM 04 LG
A4RG050N 29044A4105 160 JDM 01 IM
A4RG050R 29044B6005 160 JDM 01 IM
A4RG052N 29044B6005 160 JDM 01 IM
A4RI200I 2A04484005 160 JDM 01 FR
A4RI300I 2A04486005 160 JDM 01 FR
A4SD900A 1B04400605 160 JDM 01 IM
A4SD900B 1B04490605 160 JDM 01 IM
A4SDA00P 2904485005 192 JDM 01 IM
A4SDA01B 1B04490805 160 JDM 01 IM
A4SDA01Q 2904497105 192 JDM 01 IM
A4SH701G 2604446305 160 JDM 01 LG
A4SHB00G 2604446405 160 JDM 02 LG
A4SHC00G 2604446505 160 JDM 02 LG
A4SHC01G 2604446605 160 JDM 02 LG
A4TE001B 2E4494005 160 JDM 03 IM
A4TE002B 2E4496005 192 JDM 03 IM
A4TE200A 3D04403005 192 JDM 04 IM
A4TJ111C 3D044A4005 160 JDM 05 IM
A4TJ121B 4304594005 160 JDM 05 IM
A4TJ121C 43045A4005 160 JDM 05 IM
A4TJ121S 43045B4005 160 JDM 05 IM
AZ1G105L 5C04505207 1024 JDM 08 FR
AZ1G301F 5A04784207 1024 JDM 08 IM
AZ1G502L 6902744007 1024 JDM 09 IM
AZ1H102W 6304504107 1024 JDM 08 EX
D2UK001Q 4B0A368007 1024 JDM 07 LG
D2WD604A 3C0A384206 512 JDM 05 LG
E2SB001K 6202154007 1024 JDM 08 LG
E2WD500D 3C02057416 512 JDM 04 OB
