Postby pavlik1 » Fri Dec 04, 2009 1:14 pm
after some test , I got all the time the same error:
01: type=ssmk
02: paramname = Engine_Load_(Rel)(%)
: name[paramname,16] value[Engine_Load_(Rel)(%),0,0.000000]
03: paramid = 0x000007
: name[paramid,17] value[0x000007,7,0.000000]
04: databits = 8
05: scalingrpn = x,100,*,255,/
: name[scalingrpn,0] value[x,100,*,255,/,0,0.000000]
unrecognized option [scalingrpn] at line 5
the other idea is to have parameter names with increasing number of characters, so if length problem occurs, it will be clear what is the critical length.
like
paramname = 1234567891234567891
paramid = 0x00000E
databits = 16
scalingrpn = x,4,/
paramname = 12345678912345678912
paramid = 0x000010
databits = 8
scalingrpn = x
paramname = 123456789123456789123
paramid = 0x000011
databits = 8
scalingrpn = x,128,-,2,/
Please help to resolve :unrecognized option [scalingrpn] at line 5
pavlik1
Postby ptharris » Fri Dec 04, 2009 9:41 pm
Still no go for me either, keeps saying name parameter id to long, any ideas or fixes yet? I have played around with renaming the parameters and nothing seems to work
type=ssmk
paramname = Engine_Speed(rpm)
paramid = 0x00000E
databits = 16
scalingrpn = x,4,/
paramname = Ignition_Total_Timing(degrees)
paramid = 0x000011
databits = 8
paramname = Intake_Air_Temperature(C)
paramid = 0x000012
databits = 8
scalingrpn = x,40,-
paramname = Mass_Airflow(g/s)
paramid = 0x000013
databits = 16
scalingrpn = x,100,/
paramname = Mass_Airflow_Sensor_Voltage(V)
paramid = 0x00001D
databits = 8
scalingrpn = x,50,/
paramname = Primary_Wastegate_Duty_Cycle(%)
paramid = 0x000030
databits = 8
paramname = Fuel_Pressure_(High)(psi)
paramid = 0x000105
databits = 8
scalingrpn = x,25,/,145.0377,*
paramname = IAM*(raw_ecu_value)
paramid = 0x20118
databits = 8
scalingrpn = x
paramname = Engine_Load*(g/rev)
paramid = 0x21847
databits = 16
scalingrpn = x,.00006103515625,*
paramname = Turbo_Dynamics_Burst*(absolute_%)
paramid = 0x20CF6
databits = 16
scalingrpn = x,.00390625,*,50,-
paramname = Turbo_Dynamics_Continuous*(absolute_%)
paramid = 0x20CF4
databits = 16
paramname = Feedback_Knock_Correction*(degrees)
paramid = 0x20B80
databits = 8
scalingrpn = x,.3515625,*,45,-
paramname = Fine_Learning_Knock_Correction*(degrees)
paramid = 0x20B85
databits = 8
paramname = Manifold_Absolute_Pressure_(Direct)*(psi_absolute)
paramid = 0x2186A
databits = 16
scalingrpn = x,0.01933677,*
paramname = A/F_Sensor_#1_(Direct)*(AFR)
paramid = 0x2096E
databits = 16
scalingrpn = x,0.00179443359375,*
paramname = Manifold_Relative_Pressure_(Direct)*(psi_relative)
paramid = 0x2186C
databits = 16
scalingrpn = x,32768,-,0.01933677,*
paramname = defogger_sw
paramid = 0x64
databits = 1
offsetbits = 5
isvisible = 0
action = start
action = stop
01: type=ssmk
02: paramname = Engine_Speed(rpm)
  : name[paramname,16] value[Engine_Speed(rpm),0,0.000000]
03: paramid = 0x00000E
  : name[paramid,17] value[0x00000E,14,0.000000]
04: databits = 16
  : name[databits,22] value[16,16,16.000000]
05: scalingrpn = x,4,/
  : name[scalingrpn,18] value[x,4,/,0,0.000000]
06: paramname = Ignition_Total_Timing(degrees)
  : name[paramname,16] value[Ignition_Total_Timing(degrees),0,0.000000]
07: paramid = 0x000011
  : name[paramid,17] value[0x000011,17,0.000000]
08: databits = 8
09: scalingrpn = x,128,-,2,/
  : name[scalingrpn,18] value[x,128,-,2,/,0,0.000000]
10: paramname = Intake_Air_Temperature(C)
  : name[paramname,16] value[Intake_Air_Temperature(C),0,0.000000]
11: paramid = 0x000012
  : name[paramid,17] value[0x000012,18,0.000000]
12: databits = 8
13: scalingrpn = x,40,-
  : name[scalingrpn,18] value[x,40,-,0,0.000000]
14: paramname = Mass_Airflow(g/s)
  : name[paramname,16] value[Mass_Airflow(g/s),0,0.000000]
15: paramid = 0x000013
  : name[paramid,17] value[0x000013,19,0.000000]
16: databits = 16
17: scalingrpn = x,100,/
  : name[scalingrpn,18] value[x,100,/,0,0.000000]
18: paramname = Mass_Airflow_Sensor_Voltage(V)
  : name[paramname,16] value[Mass_Airflow_Sensor_Voltage(V),0,0.000000]
19: paramid = 0x00001D
  : name[paramid,17] value[0x00001D,29,0.000000]
20: databits = 8
21: scalingrpn = x,50,/
  : name[scalingrpn,18] value[x,50,/,0,0.000000]
22: paramname = Primary_Wastegate_Duty_Cycle(%)
  : name[paramname,16] value[Primary_Wastegate_Duty_Cycle(%),0,0.000000]
23: paramid = 0x000030
  : name[paramid,17] value[0x000030,48,0.000000]
24: databits = 8
25: scalingrpn = x,100,*,255,/
  : name[scalingrpn,18] value[x,100,*,255,/,0,0.000000]
26: paramname = Fuel_Pressure_(High)(psi)
  : name[paramname,16] value[Fuel_Pressure_(High)(psi),0,0.000000]
27: paramid = 0x000105
  : name[paramid,17] value[0x000105,261,0.000000]
28: databits = 8
29: scalingrpn = x,25,/,145.0377,*
  : name[scalingrpn,18] value[x,25,/,145.0377,*,0,0.000000]
30: paramname = IAM*(raw_ecu_value)
  : name[paramname,16] value[IAM*(raw_ecu_value),0,0.000000]
31: paramid = 0x20118
  : name[paramid,17] value[0x20118,131352,0.000000]
32: databits = 8
33: scalingrpn = x
  : name[scalingrpn,18] value[x,0,0.000000]
34: paramname = Engine_Load*(g/rev)
  : name[paramname,16] value[Engine_Load*(g/rev),0,0.000000]
35: paramid = 0x21847
  : name[paramid,17] value[0x21847,137287,0.000000]
36: databits = 16
37: scalingrpn = x,.00006103515625,*
  : name[scalingrpn,18] value[x,.00006103515625,*,0,0.000000]
38: paramname = Turbo_Dynamics_Burst*(absolute_%)
  : name[paramname,16] value[Turbo_Dynamics_Burst*(absolute_%),0,0.000000]
39: paramid = 0x20CF6
  : name[paramid,17] value[0x20CF6,134390,0.000000]
40: databits = 16
41: scalingrpn = x,.00390625,*,50,-
  : name[scalingrpn,18] value[x,.00390625,*,50,-,0,0.000000]
42: paramname = Turbo_Dynamics_Continuous*(absolute_%)
  : name[paramname,16] value[Turbo_Dynamics_Continuous*(absolute_%),0,0.000000]
43: paramid = 0x20CF4
  : name[paramid,17] value[0x20CF4,134388,0.000000]
44: databits = 16
45: scalingrpn = x,.00390625,*,50,-
46: paramname = Feedback_Knock_Correction*(degrees)
  : name[paramname,16] value[Feedback_Knock_Correction*(degrees),0,0.000000]
47: paramid = 0x20B80
  : name[paramid,17] value[0x20B80,134016,0.000000]
48: databits = 8
49: scalingrpn = x,.3515625,*,45,-
  : name[scalingrpn,18] value[x,.3515625,*,45,-,0,0.000000]
50: paramname = Fine_Learning_Knock_Correction*(degrees)
  : name[paramname,16] value[Fine_Learning_Knock_Correction*(degrees),0,0.000000]
51: paramid = 0x20B85
  : name[paramid,17] value[0x20B85,134021,0.000000]
52: databits = 8
53: scalingrpn = x,.3515625,*,45,-
54: paramname = Manifold_Absolute_Pressure_(Direct)*(psi_absolute)
  : name[paramname,16] value[Manifold_Absolute_Pressure_(Direct)*(psi_absolute),0,0.000000]
55: paramid = 0x2186A
  : name[paramid,17] value[0x2186A,137322,0.000000]
56: databits = 16
57: scalingrpn = x,0.01933677,*
  : name[scalingrpn,18] value[x,0.01933677,*,0,0.000000]
58: paramname = A/F_Sensor_#1_(Direct)*(AFR)
  : name[paramname,16] value[A/F_Sensor_#1_(Direct)*(AFR),0,0.000000]
log parameter name too long at line 58
ptharris
Postby ptharris » Fri Dec 04, 2009 9:46 pm
yet this works for me
type=ssmk
paramid = 0x00000E
databits = 16
scalingrpn = x,4,/
paramid = 0x000011
databits = 8
paramid = 0x000012
databits = 8
scalingrpn = x,40,-
paramname = Throttle_Opening_Angle(%)
paramid = 0x000015
databits = 8
paramname = A/F_Sensor_#1(AFR)
paramid = 0x000046
databits = 8
scalingrpn = x,128,/,14.7,*
paramname = IAM(multiplier)
paramid = 0x0000F9
databits = 8
scalingrpn = x,16,/
paramid = 0x21847
databits = 16
paramid = 0x20B80
databits = 8
paramid = 0x20B85
databits = 8
paramname = Fine_Learning_Table_Offset*(index_position)
paramid = 0x20B86
databits = 8
scalingrpn = x,1,+
paramid = 0x2186C
databits = 16
paramid = 0x64
databits = 1
offsetbits = 5
isvisible = 0
action = start
action = stop
01: type=ssmk
04: databits = 16
08: databits = 8
12: databits = 8
14: paramname = Throttle_Opening_Angle(%)
  : name[paramname,16] value[Throttle_Opening_Angle(%),0,0.000000]
15: paramid = 0x000015
  : name[paramid,17] value[0x000015,21,0.000000]
16: databits = 8
17: scalingrpn = x,100,*,255,/
18: paramname = A/F_Sensor_#1(AFR)
  : name[paramname,16] value[A/F_Sensor_#1(AFR),0,0.000000]
19: paramid = 0x000046
  : name[paramid,17] value[0x000046,70,0.000000]
20: databits = 8
21: scalingrpn = x,128,/,14.7,*
  : name[scalingrpn,18] value[x,128,/,14.7,*,0,0.000000]
22: paramname = IAM(multiplier)
  : name[paramname,16] value[IAM(multiplier),0,0.000000]
23: paramid = 0x0000F9
  : name[paramid,17] value[0x0000F9,249,0.000000]
24: databits = 8
25: scalingrpn = x,16,/
  : name[scalingrpn,18] value[x,16,/,0,0.000000]
26: paramname = Engine_Load*(g/rev)
27: paramid = 0x21847
28: databits = 16
29: scalingrpn = x,.00006103515625,*
30: paramname = Feedback_Knock_Correction*(degrees)
31: paramid = 0x20B80
32: databits = 8
33: scalingrpn = x,.3515625,*,45,-
34: paramname = Fine_Learning_Knock_Correction*(degrees)
35: paramid = 0x20B85
36: databits = 8
37: scalingrpn = x,.3515625,*,45,-
38: paramname = Fine_Learning_Table_Offset*(index_position)
  : name[paramname,16] value[Fine_Learning_Table_Offset*(index_position),0,0.000000]
39: paramid = 0x20B86
  : name[paramid,17] value[0x20B86,134022,0.000000]
40: databits = 8
41: scalingrpn = x,1,+
  : name[scalingrpn,18] value[x,1,+,0,0.000000]
42: paramname = Manifold_Relative_Pressure_(Direct)*(psi_relative)
  : name[paramname,16] value[Manifold_Relative_Pressure_(Direct)*(psi_relative),0,0.000000]
43: paramid = 0x2186C
  : name[paramid,17] value[0x2186C,137324,0.000000]
44: databits = 16
45: scalingrpn = x,32768,-,0.01933677,*
  : name[scalingrpn,18] value[x,32768,-,0.01933677,*,0,0.000000]
46: paramname = defogger_sw
  : name[paramname,16] value[defogger_sw,0,0.000000]
47: paramid = 0x64
  : name[paramid,17] value[0x64,100,0.000000]
48: databits = 1
  : name[databits,22] value[1,1,1.000000]
49: offsetbits = 5
  : name[offsetbits,23] value[5,5,5.000000]
50: isvisible = 0
  : name[isvisible,25] value[0,0,0.000000]
51: conditionrpn = defogger_sw,1,==
  : name[conditionrpn,48] value[defogger_sw,1,==,0,0.000000]
52: action = start
  : name[action,49] value[start,0,0.000000]
53: conditionrpn = defogger_sw,0,==
  : name[conditionrpn,48] value[defogger_sw,0,==,0,0.000000]
54: action = stop
  : name[action,49] value[stop,0,0.000000]
--- log config dump ---
channel type: ssmk
protocol id: 3
baud: 4800
param name: Engine_Speed(rpm)
param id: 0x0000000E
read width: 2 bytes
data width: 16 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,4.000000,/
param name: Ignition_Total_Timing(degrees)
param id: 0x00000011
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,128.000000,-,2.000000,/
param name: Intake_Air_Temperature(C)
param id: 0x00000012
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,40.000000,-
param name: Throttle_Opening_Angle(%)
param id: 0x00000015
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,100.000000,*,255.000000,/
param name: A/F_Sensor_#1(AFR)
param id: 0x00000046
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,128.000000,/,14.700000,*
param name: IAM(multiplier)
param id: 0x000000F9
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,16.000000,/
param name: Engine_Load*(g/rev)
param id: 0x00021847
read width: 2 bytes
data width: 16 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,0.000061,*
param name: Feedback_Knock_Correction*(degrees)
param id: 0x00020B80
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,0.351563,*,45.000000,-
param name: Fine_Learning_Knock_Correction*(degrees)
param id: 0x00020B85
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
param name: Fine_Learning_Table_Offset*(index_position)
param id: 0x00020B86
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,1.000000,+
param name: Manifold_Relative_Pressure_(Direct)*(psi_relative)
param id: 0x0002186C
read width: 2 bytes
data width: 16 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,32768.000000,-,0.019337,*
param name: defogger_sw
param id: 0x00000064
read width: 1 bytes
data width: 1 bits
data offset: 5 bits
float: 0
low priority: 0
scaling: x
trigger action: start condition: defogger_sw,1.000000,==
trigger action: stop condition: defogger_sw,0.000000,==
--- storage info ---
log stringlist: 400 chars
log floatlist: 15 floats
worst case ssm request is 51 bytes long, response 20 bytes long and will be sent every 200000us (147893us is fastest possible)
logging interval will be 200000us
ptharris
Postby pavlik1 » Sat Dec 05, 2009 1:50 am
Strange becouse the parameter name is longer in row 54 than 58
56: databits = 16
I will try your last working file and post the result
pavlik1
Postby freakin » Sat Dec 05, 2009 2:54 am
I have posted in colby's main thread to see if he can find out what is going on with the logger.
freakin
Postby pavlik1 » Sat Dec 05, 2009 2:59 pm
to ptharis
with the code you claim to be working I got:
01: type=ssmk
04: databits = 16
: name[scalingrpn,0] value[x,4,/,0,0.000000]
pavlik1
Postby ptharris » Sat Dec 05, 2009 6:45 pm
pavlik1 wrote:to ptharis
01: type=ssmk
04: databits = 16
i dont claim it to be working, it is working
this is for A4SD900B jdm sti v7, not applicable to anything else, unless your ecu has the same storage address for all the parameters
ptharris
Postby pavlik1 » Sun Dec 06, 2009 3:22 am
Hello,
There is no doubt it is working with your ecu,
may be as general suggestion, when posting the file please also write the type of your ECU. In this way people with the same ECU can test it. Otherwise is a big mess and very hard to troubleshoot.
pavlik1
Postby ptharris » Wed Dec 09, 2009 12:22 am
Freakin
Any update on your tool? Seems to be a few of us having the same issues (ie no log produced, not logging to sd card)
Thanks Phil
ptharris
Postby ptharris » Sun Dec 13, 2009 1:19 pm
any news? :(
ptharris
Postby lonertic » Tue Dec 15, 2009 3:51 pm
anyone? I'm getting the "unrecognised" error too on my latest OP2 .. so I'm using a laptop to log right now... :(
lonertic
Postby ptharris » Mon Dec 21, 2009 10:05 am
ptharris wrote:Freakin
Thanks Phil
ptharris
Postby freakin » Mon Dec 21, 2009 11:30 am
hey, Im back. Reading back through some of the previous posts, please can you clarify exactly what issues you have outstanding, most of the last ones don't seem to be an issue with the config but the logger.
freakin
Postby cboles » Tue Mar 09, 2010 5:58 pm
Not to make life harder for you, but I have posted a new version at the top of the logging thread. Take a look, read the release info carefully, and check it out! It adds some new features and was to log slow parameters that you may want to add to your program.
Postby mfb » Sun Mar 28, 2010 11:06 pm
Colby,
Will OP kline be able to log ecus that are locked y Cobb AP and Ecutek?
mfb
