Page 5 of 8
Re: Openport standalone Config tool Beta
Sat Nov 07, 2009 4:45 pm
by ptharris
last .exe is not producing any .csv files for me at all. Lights on op2 dont flash fast either (red/green) maybe another faulty trigger in the .txt produced?
Wed Nov 11, 2009 1:58 pm
by freakin
pt, you still having problems?, can your post your config file
Sat Nov 14, 2009 4:59 pm
by dan az
when i try to run the program i get "component 'mscomctl.ocx' or one of its dependencies not correctly registered: a file is missing or invalid" what the heck is that all about?
Sat Nov 14, 2009 5:40 pm
by enthusiast
dan az wrote:when i try to run the program i get "component 'mscomctl.ocx' or one of its dependencies not correctly registered: a file is missing or invalid" what the heck is that all about?
What OS are you running? Read my post on page three. Even if you are not running Win7 it will fix your problem.
Sat Nov 14, 2009 6:24 pm
by dan az
windows vista, ive been trying to install that mscomctl but its not working yet
Sat Nov 14, 2009 6:37 pm
by enthusiast
Open up the command prompt as administrator.
Sat Nov 14, 2009 6:48 pm
by dan az
heres what i get. " the module "mscomctl.ocx' failed to load. make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent .DLL files. the specified module could not be found.
Sat Nov 14, 2009 6:54 pm
by enthusiast
dan az wrote:heres what i get. " the module "mscomctl.ocx' failed to load. make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent .DLL files. the specified module could not be found.
When you run "regsvr32 mscomctl.ocx" you either need to be in the same directory as the mscomctl.ocx file or it has to be in your path. Keep it simple and just open up a command prompt in the same window where you extracted the files at.
Sat Nov 14, 2009 8:13 pm
by dan az
ill give that a try, but the bigger issue im having is that with ecu flash, when i click read ecu, i get a blank box that only gives me the option to cancel.
Mon Nov 16, 2009 11:07 pm
by senya
with metric ecu defs program not work
Win XP SP3
- bug.JPG (45.69 KiB) Viewed 72710 times
Tue Nov 17, 2009 12:04 pm
by freakin
senya, you have the RR log defs set to be the same as the ecu defs, this is wrong and you need to change the log one to the correct metric units file.
Wed Nov 18, 2009 1:47 am
by senya
freakin wrote:senya, you have the RR log defs set to be the same as the ecu defs, this is wrong and you need to change the log one to the correct metric units file.
Oops. Thank you. All works
Wed Nov 25, 2009 2:38 pm
by csdahlberg
I've tried running logcfg.exe on both Windows 7 (64-bit) and Windows XP Pro (32-bit) with the same results:
- Code: Select all
20091125150117 ERROR logcfg Mainform Form_Load ERROR:91(10420) Object variable or With block variable not set
RomRaider is installed and configured correctly (both ecu and logging defs), I have installed VB6 Common Controls, and have msxml2.dll and scrrun.dll in System32. I'll probably just manually create a config file soon if I can't get past this error, but let me know if you want any more info from me.
Wed Nov 25, 2009 2:43 pm
by freakin
hmm, interesting. im running W7 64bit without issue. Can you post a Screenshot? In the mean time ill go check the code.
Wed Nov 25, 2009 3:16 pm
by csdahlberg
here's a screenshot
