Postby ptharris » Sat Nov 07, 2009 4:45 pm
last .exe is not producing any .csv files for me at all. Lights on op2 dont flash fast either (red/green) maybe another faulty trigger in the .txt produced?
ptharris
Postby freakin » Wed Nov 11, 2009 1:58 pm
pt, you still having problems?, can your post your config file
freakin
Postby dan az » Sat Nov 14, 2009 4:59 pm
when i try to run the program i get "component 'mscomctl.ocx' or one of its dependencies not correctly registered: a file is missing or invalid" what the heck is that all about?
dan az
Postby enthusiast » Sat Nov 14, 2009 5:40 pm
dan az wrote:when i try to run the program i get "component 'mscomctl.ocx' or one of its dependencies not correctly registered: a file is missing or invalid" what the heck is that all about?
What OS are you running? Read my post on page three. Even if you are not running Win7 it will fix your problem.
enthusiast
Postby dan az » Sat Nov 14, 2009 6:24 pm
windows vista, ive been trying to install that mscomctl but its not working yet
dan az
Postby enthusiast » Sat Nov 14, 2009 6:37 pm
Open up the command prompt as administrator.
enthusiast
Postby dan az » Sat Nov 14, 2009 6:48 pm
heres what i get. " the module "mscomctl.ocx' failed to load. make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent .DLL files. the specified module could not be found.
dan az
Postby enthusiast » Sat Nov 14, 2009 6:54 pm
dan az wrote:heres what i get. " the module "mscomctl.ocx' failed to load. make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent .DLL files. the specified module could not be found.
When you run "regsvr32 mscomctl.ocx" you either need to be in the same directory as the mscomctl.ocx file or it has to be in your path. Keep it simple and just open up a command prompt in the same window where you extracted the files at.
enthusiast
Postby dan az » Sat Nov 14, 2009 8:13 pm
ill give that a try, but the bigger issue im having is that with ecu flash, when i click read ecu, i get a blank box that only gives me the option to cancel.
dan az
Postby senya » Mon Nov 16, 2009 11:07 pm
with metric ecu defs program not work :(
Win XP SP3
senya
Postby freakin » Tue Nov 17, 2009 12:04 pm
senya, you have the RR log defs set to be the same as the ecu defs, this is wrong and you need to change the log one to the correct metric units file.
freakin
Postby senya » Wed Nov 18, 2009 1:47 am
freakin wrote:senya, you have the RR log defs set to be the same as the ecu defs, this is wrong and you need to change the log one to the correct metric units file.
Oops. Thank you. All works :oops:
senya
Postby csdahlberg » Wed Nov 25, 2009 2:38 pm
I've tried running logcfg.exe on both Windows 7 (64-bit) and Windows XP Pro (32-bit) with the same results:
20091125150117   ERROR   logcfg   Mainform   Form_Load   ERROR:91(10420) Object variable or With block variable not set
RomRaider is installed and configured correctly (both ecu and logging defs), I have installed VB6 Common Controls, and have msxml2.dll and scrrun.dll in System32. I'll probably just manually create a config file soon if I can't get past this error, but let me know if you want any more info from me.
csdahlberg
Postby freakin » Wed Nov 25, 2009 2:43 pm
hmm, interesting. im running W7 64bit without issue. Can you post a Screenshot? In the mean time ill go check the code.
freakin
Postby csdahlberg » Wed Nov 25, 2009 3:16 pm
here's a screenshot
csdahlberg
