Postby freakin » Sat Oct 31, 2009 5:41 pm
I have created a little app that will build the logcfg.txt file and i need some feedback
Current limitations and brief description
*You must have a working romraider installed (it gets the logger.xml and ecu_defs.xml file location from the romraider settings.xml file)
*it currently only does standard and extended params, not calculated ones.
*its a bit rough round the edges
*you have the option of the defogger, rpm or coolant Temp for start stopping
*there is no priority stuff in yet
*some parameters dont work because they are too long (if someone can work out the max length for me that would be appreciated)
Basic instructions
Open app (duh)
select your ECU from the drop down list
Select the parameters by ticking the boxes
click make logcfg.txt
copy logcfg.txt to your OP2 sd card
Test and provide me with some feed back as to what doesn't work
If the application errors then it will create an output text file, please forward this to me
[img]http://bit.ly/1C5Ogh[/img]
[attachment=0]logcfg.exe[/attachment]
someone asked if i would take a donation for my work, after thinking about it for a while i have decided that if any one else wants to donate then it can go towards the keep the wife happy fund for me spending hours at the computer.
I am not asking for anyone to donate and my application is free for all to use so enjoy and donate if your feeling a bit flush and want to keep the wife happy :).
[url=https://www.paypal.com/cgi-bin/webscr?cmd=_s-xclick&hosted_button_id=9446242][img]https://www.paypal.com/en_US/GB/i/btn/btn_donateCC_LG.gif[/img][/url]
logcfg.exe
changed coolant logger switch and fixed first run issue
(132 KiB) Downloaded 10831 times
freakin
Postby mickeyd2005 » Sat Oct 31, 2009 7:10 pm
This looks like a cool app. However, I get a run-time error '91': Object variable or With block variable not set.
Any advice?
mickeyd2005
Postby CasopoliS » Sat Oct 31, 2009 8:30 pm
Very cool app. Runtime error as well. Runtime error 5: Invalid procedure call or argument. The error comes when I select my ECU from the list.
Vista 64bit
CasopoliS
Postby enthusiast » Sat Oct 31, 2009 9:25 pm
Where does it write the config file at? I cannot find it.
Works on XP SP3 with .Net 3.5 SP1
EDIT: Re-read your instructions and saw that it writes to c:\logcfg.txt.
enthusiast
Postby legaulois » Sat Oct 31, 2009 10:13 pm
i have runtime error 70 - Permission denied :(
in vista and framework 3.5
legaulois
Postby legaulois » Sat Oct 31, 2009 10:26 pm
It works, should start in Administrator :D :wink:
legaulois
Postby freakin » Sun Nov 01, 2009 12:24 am
To all those with errors I have added some error handling, it should create a text file in the same directory as the exe. Can you send me the output please and I will investigate
freakin
Postby freakin » Sun Nov 01, 2009 1:38 am
updated version added to top post listbox control tidied and some logging added.
Has anyone been able to validate my RPN calculations ?
freakin
Postby freakin » Sun Nov 01, 2009 2:49 am
apart from RPM and the defogger what are the common on/off controls?
freakin
Postby legaulois » Sun Nov 01, 2009 3:19 am
I have a TSI 2008 and at the moment this type of addressing 0xFF63FC does not work
type = ssmcan
paramname = A/F_Sensor_#1(AFR)
paramid = 0x000046
databits = 8
scalingrpn = x,128,/,14.7,*
paramname = IAM(multiplier)
paramid = 0x0000F9
databits = 8
scalingrpn = x,16,/
paramname = Engine_Load_(4-Byte)*(g/rev)
paramid = 0xFF65D4
isfloat = 1
scalingrpn = x
paramname = CL/OL_Fueling*(status)
paramid = 0xFF9CF1
databits = 8
scalingrpn = x,6,+
paramname = Fine_Learning_Knock_Correction_(4-byte)*(degrees)
paramid = 0xFF7CDC
isfloat = 1
scalingrpn = x
paramname = Knock_Correction_Advance_(4-byte)*(degrees)
paramid = 0xFF7C3C
isfloat = 1
scalingrpn = x
paramname = Fuel_Injector_#1_Latency_(4-byte)*(ms)
paramid = 0xFF6F44
isfloat = 1
scalingrpn = x,.001,*
paramname = Manifold_Absolute_Pressure_(4-byte)*(bar_absolute)
paramid = 0xFF63FC
isfloat = 1
scalingrpn = x,0.001333224,*
paramname = Ignition_Base_Timing*(degrees)
paramid = 0xFF7988
isfloat = 1
scalingrpn = x
paramname = Requested_Torque*(raw_ecu_value)
paramid = 0xFF7FA4
isfloat = 1
scalingrpn = x
paramname = A/F_Correction_#1_(2-byte)**(%)
paramid = 0xFF6A2A
databits = 16
scalingrpn = x,.01220703,*,100,-
paramname = A/F_Sensor_#1_(2-byte)**(estimated_AFR)
paramid = 0xFF6A18
databits = 16
scalingrpn = x,.0001220703,*,14.7,*
paramname = IAM_(1-byte)**(multiplier)
paramid = 0xFF6A4F
databits = 8
scalingrpn = x,.0625,*
paramname = defogger_sw
paramid = 0x64
databits = 1
offsetbits = 5
isvisible = 0
Action = start
action = stop
legaulois
Postby freakin » Sun Nov 01, 2009 3:59 am
Do you mean generally or as an output from the tool? Also have you tried the other mode, I read somewhere that one supports the extra bits on newer ecu's but runs slower.
freakin
Postby CasopoliS » Sun Nov 01, 2009 6:26 am
Ok now it lets me select my ECU but hangs up and gets into a huge loop and locks up. It created a 6MB log file full of errors. I have to kill the process, the "X" does not work in the application.
20091101091946   ERROR   logcfg   Form1   loadDefs   ERROR:5(10150) Invalid procedure call or argument
20091101091946   ERROR   logcfg   Form1   loadDefs   ERROR:424(10160) Object required
20091101091946   ERROR   logcfg   Form1   loadDefs   ERROR:424(10170) Object required
20091101091946   ERROR   logcfg   Form1   loadDefs   ERROR:424(10200) Object required
20091101091946   ERROR   logcfg   Form1   loadDefs   ERROR:424(10220) Object required
CasopoliS
Postby freakin » Sun Nov 01, 2009 7:18 am
CasopoliS, can you download the version 1.2.23 at the top should enable me to see what the problem is.If it errors can you get a screen shot of the message box that will appear with the app in the back ground so I can see the bottom box
you could also try putting these two files in your windows\system32 directory if they don't already exist (don't overwrite your existing ones if they exist)
msxml2.dll.txt
you need to remove the .txt extenion from the filename (you may not be able to see this by default in explorer)
(685 KiB) Downloaded 3744 times
scrrun.dll.txt
(168 KiB) Downloaded 3669 times
freakin
Postby mickeyd2005 » Sun Nov 01, 2009 10:13 am
freakin wrote:apart from RPM and the defogger what are the common on/off controls?
Coolant temperature would be a good trigger.
mickeyd2005
Postby enthusiast » Sun Nov 01, 2009 10:17 am
When I click on "Choose logging start stop" and select use "Defogger" the output in the LogCfg.txt is:
conditionrpn = engine_speed,1,==
Action = start
action = stop
should be:
;conditionrpn = defogger_sw,1,==
;action = start
;conditionrpn = defogger_sw,0,==
;action = stop
enthusiast
