Postby gwigga » Wed Apr 25, 2012 2:45 am
I want to use RPm to trigger the logging to start
this was copied from another person I know but the it doesn't work
the logcfg.out file states theres something wrong with it
conditionrpn = RPM,0,>
action = start
conditionrpn = RPM,0,==
action = stop
also could you tell me what to set to start the logging at 2000rpm and finsih when it drops below 2000
gwigga
Postby helmut_hair » Fri Apr 27, 2012 9:27 am
cboles wrote:
* The current version of the beta has no power management, and the OBD port is always on, so it is possible to drain your battery if you leave the OP2 plugged in for several days while your car is off.
Is it possible that power management can be implemented? I'm looking at doing some sort of permanent install of the OP2 in my car.
helmut_hair
Postby endrswrd » Thu Oct 25, 2012 8:44 am
I am looking for some help generating my logcfg.txt file.
Car is 2011 USDM WRX STi 5 door
ECUID : AE5IB00V. Although, The rom currently flashed on the car may be the sedan rom. I plan on copying my tune back to the correct rom for the car, even though they both work just as expected.
I have this so far
Code:
type=ssmk
paramname = Coolant
paramid = 0x000008
databits = 8
scalingrpn = x,40,-
paramname = A/F_Correction_#1(%)
paramid = 0x000009
databits = 8
scalingrpn = x,128,-,100,*,128,/
paramname = A/F_Learning_#1(%)
paramid = 0x00000A
databits = 8
paramname = RPM
paramid = 0x00000E
databits = 16
scalingrpn = x,0.25,*
sampinterval = 5
paramname = Throttle Opening(%)
paramid = 0x000015
databits = 8
scalingrpn = x,0.3921569,*
paramname = A/F_Sensor_#1(AFR)
paramid = 0x000046
databits = 8
scalingrpn = x,128,/,14.7,*
paramname = CL/OL_Fueling*(status)
paramid = 0xFFA44D
databits = 8
scalingrpn = x,6,+
paramname = MAFG/s
paramid = 0x000013
databits = 16
scalingrpn = x,0.01,*
sampinterval = 2
paramname = MAFv
paramid = 0x00001D
databits = 8
scalingrpn = x,0.02,*
paramname = EngineLoad
paramid = 0x000007
databits = 8
scalingrpn = x,100,*,255,/
paramname = Manifold_Absolute_Pressure
paramid = 0xFF6394
isfloat = 1
scalingrpn = x,0.01933677,*
paramname = IPW ; injector #1 pulse width
paramid = 0x000011
scalingrpn = x,0.256,*
paramname = Knock_Sum*(count)
paramid = 0xFF7FEC
databits = 8
scalingrpn = x
conditionrpn = Coolant,76,>
action = start
action = stop
Everything works except engine load, and CL/OL status. I am questioning MAFv but that may just be a resolution issue(numbers seem a little high for just cruising but the car is new to me so I have yet to really determine *normal numbers) . The issues with CL/OL status and engine load seem to either be incorrect scaling or incorrect paramid. Ive scoured the internet looking to correct these two params with limited success. I was able to fix many of the parameters I was targeting. (I am working on the GR stumble fix. I have a very slight stumble in the 28-3200 rpm range. Doesnt even happen very often. But I would like to smooth it out with the compensation tables for such issue.)
Any help would be appreciated. I tried pulling the data out of my logging xml file. But the values werent coming back scaled properly....
endrswrd
Postby rotorB » Sat Sep 21, 2013 7:10 am
Hi guys.
I want to log G-sensor of my Galant VR-4.
It works on EvoScan, but how can i add it to logcfg.txt, what value of 'type' parameter i should use?
rotorB
Postby pete25r » Tue Nov 12, 2013 12:44 pm
action = start
action = stop
also could you tell me what to set to start the logging at 2000rpm and finsih when it drops below 2000gwigga
change the "0"s
conditionrpn = RPM,2000,>
action = start
conditionrpn = RPM,1999,==
action = stop
pete25r
Postby kangsta » Thu Jan 28, 2016 6:46 pm
has there been any further development on this? Is there a central wiki or repository with documentation on the supported logging modes like more generic ISO 14230-4 KWP
kangsta
