Postby cboles » Fri Sep 18, 2009 11:15 am
Postby cboles » Fri Sep 18, 2009 5:49 pm
If they all change from 0x42 to 0x52 for the relative jump (they should if the larger span of this function has no changes), then yes.
Postby unchi » Fri Sep 18, 2009 5:53 pm
rom ID's and the mode 23 stuff
52690019
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f121" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8aafd" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab02" scaling="Hex16"/>
52340007 -> 52340010
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f145" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8aa59" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8aa5e" scaling="Hex16"/>
52680015 -> 52680020
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ab11" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8ab16" scaling="Hex16"/>
52360018
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7f58d" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8ada5" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8adaa" scaling="Hex16"/>
53600010
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" type="1D" address="0x7efbd" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" type="1D" address="0x8aa61" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" type="1D" address="0x8aa66" scaling="Hex16"/>
53050006
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7f145" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8a9f1" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8a9f6" type="1D" scaling="Hex16"/>
54060007
<table name="IFMode 0x05 -> 0x23 #1" category="Misc" address="7efc1" type="1D" scaling="Hex8"/>
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8aa7d" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8aa82" type="1D" scaling="Hex16"/>
54070007
<table name="IFMode 0x05 -> 0x23 #2" category="Misc" address="8aa69" type="1D" scaling="Hex8"/>
<table name="DoMode 0x42 -> 0x52" category="Misc" address="8aa6e" type="1D" scaling="Hex16"/>
unchi
Postby cboles » Sat Sep 19, 2009 9:16 am
Yes. I noticed they are all the same, so it should work. Notice that the addresses I used in my example are not the same - they are shifted a few bytes earlier so that more data is included in the pattern.
Postby Tephra » Sat Sep 19, 2009 7:38 pm
well AFAIK only 1 person has bricked their ECU by doing my mode23 mod.
Thats because the didn't ENSURE the "before" numbers matched in their ROM...
It can't really get much easier :)
If we can work out the proper diagnostics mode then we wouldn't need to change 3 bytes at all :)
Tephra
Postby unchi » Sun Sep 20, 2009 6:37 pm
Tephra wrote:well AFAIK only 1 person has bricked their ECU by doing my mode23 mod.
i had 3 bricked ecu's from people YESTERDAY
haha
all from doing mode 23 wrong
unchi
Postby Tephra » Sun Sep 20, 2009 6:57 pm
first i've heard of it..
follow the directions in the "illustrated" thread - you can't really stuff it up.
maybe some of these guys should sell their OP20 cable ;)
Tephra
Postby cboles » Sun Sep 20, 2009 9:24 pm
I think the bloblist way really helps though. Even I accidentally cut and pasted your definitions into the wrong XML and then loaded that ROM - and guess what - there was coincidentally a 0x05 in the first byte I needed to change to 0x23 - even though I was in the wrong code area.
Tephra wrote:first i've heard of it..
Postby ptharris » Wed Sep 23, 2009 1:20 am
Colby, I installed the Beta software and plugged it into my 08 sti, it logged the parmeters in the .txt file i placed on the sd card. However it now does not log to SD card. Ive checked the OP2 firmware and confirmed it is 1.10.2658. The OP2 is no longer flashing fast when in the OBDII socket as it did last night. It logs to pc fine though. Any ideas. Cheers Phil
ptharris
Postby cboles » Wed Sep 23, 2009 11:36 am
ptharris wrote:Colby, I installed the Beta software and plugged it into my 08 sti, it logged the parmeters in the .txt file i placed on the sd card. However it now does not log to SD card. Ive checked the OP2 firmware and confirmed it is 1.10.2658. The OP2 is no longer flashing fast when in the OBDII socket as it did last night. It logs to pc fine though. Any ideas. Cheers Phil
Hi Phil-
I'm a little unclear on what you are saying. Are you saying it worked for a while, and now it does not? Can you ZIP up and post a copy of your logcfg.txt, logcfg.out and any .csv files you have?
Thanks,
Postby ptharris » Wed Sep 23, 2009 12:50 pm
Hi Colby
Yes it worked fine, I went to use it last night in stand alone mode (ie no laptop connected) went for a drive and come back, plugged into laptop and no .csv was produced. I plugged back into car and looked at the lights, I noticed it was not flashing the lights at a fast pace like it did when it logged to sdcard the first time.
I have since unistalled ecuflash and OP2 drivers, rebooted laptop, fresh install of ecuflash 1.42.2595 and redownloaded the beta software, run installer and tried agian, still with no luck
I have formated sd card to FAT32 system and put the subaru can logcfg.txt file on the sd card (renamed to logcfg.txt) and still no joy (I also did this the 1st attempt which was succsseful)
Unfortunatley I have deleted the .csv file and logcfg.out files when I formated the SD card
Phil
ptharris
Postby cboles » Wed Sep 23, 2009 1:10 pm
i'm wondering if it is SD card related. can you try formatting FAT16 ("FAT") and seeing if that makes a difference?
ptharris wrote:Hi Colby
Phil
Postby ptharris » Wed Sep 23, 2009 1:27 pm
will do tonight and report back. Phil
ptharris
Postby ptharris » Wed Sep 23, 2009 11:12 pm
I formatted to FAT and retried, still no luck, the lights do not flash fast as they did the 1st time and no .csv file was produced
I used the Subaru can logcfg.txt and it produced a logcfg.out (but it is 0kb) not sure how to attach them here
Phil
ptharris
Postby ptharris » Thu Sep 24, 2009 11:48 am
Colby I wonder if it is worth rolling the OP2 firmware back to what is included with ecuflash 1.42? How do I do this? Then try reinstall the beta version. Just a thought
Phil
ptharris
