For me the sample config file was wrong. I used
paramname = mylc1.afr
paramid = 0x0101
scalingrpn = x,14.7,*
cboles wrote:NTFS wont work. Only FAT16 and FAT32. I'll need to look into what is going on. Unfortunately, I haven't seen any problems here.kewlboxer2 wrote:Im having this issue as well. Its a 1gb transcend card. I have it setup for coolant temp on and rpm 0 off. Sometimes it will work sometimes it wont. green light flashes when i have the car off. when i start it up the blue flashes once, then its just red and green flashing(normal), but the blue never comes on to start the writing.
I think i have the card formatted for fat32. maybe i should try ntfs? or a whole new card
kewlboxer2 wrote:
I know the previous firmware for the sd logging worked like a champ. any way i try to downgrade the firmware incase its not my card?
Also what size card can the OP2.0 take?
cboles wrote:The OP2 can use any SD or SDHC card. I don't have a good way to downgrade the firmware - what previous version worked for you? Was it before I added the background file system? That was a major, but necessary overhaul to allow faster logging speeds and prevent SD card delays from affecting the logging interval.
For all of the users out there having a problem: I still haven't seen any of your logcfg.txt files - please send them so I can see if I can reproduce the problem here.kewlboxer2 wrote:
zcivic wrote:Ok I am confused on how to make the log file to put on the SD card. I will admit I'm not very good with some of this stuff. Do I just need to create the log.txt file using the peram creater and place it on my card. I was wanting to use the rear def as a trigger. If someone can get me to a starting point I would greatly appreciate it. I have done everything just unsure about the txt file.
I'm using and 02 WRX A4SGE01C ECU.
Have a working ECUflash and OP2. Its ECUflash 1.43 beta and the OP2 have been licensced
Thanks,
Randy
kewlboxer2 wrote:It cant take just any SD or SDHC card. I have an 8gb card. all I get is a the color cycle.
I have fiarly good luck today with the logging. only had to unplug once out of 6 starts.
here is my logcfg and logcfg.out
i haven't been logging for a while know, but the firmware the worked perfect for me was the one about 4-5 months after sd logging was available, i think. i dont have my old version anymore because i have the newest on it right now.cboles wrote:The OP2 can use any SD or SDHC card. I don't have a good way to downgrade the firmware - what previous version worked for you? Was it before I added the background file system? That was a major, but necessary overhaul to allow faster logging speeds and prevent SD card delays from affecting the logging interval.
mfb wrote:cboles wrote:The OP2 can use any SD or SDHC card. I don't have a good way to downgrade the firmware - what previous version worked for you? Was it before I added the background file system? That was a major, but necessary overhaul to allow faster logging speeds and prevent SD card delays from affecting the logging interval.
Hi Colby,
I already posted my LogCfg, please see here http://forums.openecu.org/viewtopic.php?f=57&t=4319&start=435#p23345
mdedwar wrote:For me the sample config file was wrong. I used
paramid = 0x0101
cboles wrote:Does your 8GB card work as USB as a storage device using the OP2? Is it formatted FAT32? I'll try running your config and seeing if I run into trouble.
cboles wrote:I ran your exact logcfg.txt on my 08 STI (some of the RAM address are incorrect, but I didn't care). I hit the defroster over 20 times. Each time it started logging normally. I checked with my PC and all of the log files are OK. I think it has something to do with the card (and perhaps the OP2 not dealing with the resulting problem well). I am interested in getting this card from you. We can send you a different one to use meanwhile... Also, can you verify what version of firmware you have (less than version 2996, and there is a limitation of 512 bytes for the column header - and i can see yours is over 512...)?
adamw2 wrote:mdedwar wrote:For me the sample config file was wrong. I used
paramid = 0x0101
Problem solved.. it turned out to be the fact that I didn't have a terminator plug in the Serial In port of the LC-1! I had no idea this was necessary!
All working now, I just had to change 0x0102 to 0x0101 as well so that the scalingrpn does 14.7 * lambda rather than 14.7 * AFR.
Adam
MechEE wrote:For me the sample config file was wrong. I used
Confirmed for me as well: 0x0101 is the correct paramid for logging lambda on the LC-1. I was pulling my hair out trying to figure out why I was getting such a strange calculated AFR (~72:1) after flashing to the latest OpenPort firmware. It turns out it was a combination of an error in the sample LC-1 logcfg.txt suggesting the paramid should be 0x0102 and the infamous LC-1 reset bug that had a stoich of ~4.7:1 set. Oops!
I think I covered this somewhere before - it is basically a minor hw/sw design flaw in the LC-1 that can cause it to lose its settings when you you plug it into another device. What happens is that the tip terminal of the 2.5 plugs can get grounded as you plug them in, which is not a big deal in itself since it is an input, but some unfortunate protocol choices can make that glitch look like some sort of "clear calibrations" command. This isn't speculation - I heard this from the engineers at Innovate. So the solutions are to:
1) Plug the LC-1 in to the OP2 only when the LC-1 is off
2) Let the OP2 take care of the AFR scaling so that you don't notice the problem
