I’m try to using my openport2.0 for logging with SD Card, but after I install ecuflash 1.4227 here is the link,
“Here is how to install and use this beta:
* Download and install
http://mail.tactrix.com/ecuflash/ecufla ... n_beta.exe* Run EcuFlash and do a Help|Licensing operation. This will cause a firmware update to 1.10.xxxx, which has the logging support.
* If you go to the C:\Program Files\OpenECU\OpenPort 2.0\samples\logging directory you will see some example logging configuration files. These are text files you can open in a text editor and read.
* Copy the appropriate text file to your microSD card and rename it logcfg.txt. Make sure your text editor does not end up writing the file as logcfg.txt.txt.
* Disconnect the OP2 from your PC and plug it in to your car and go for a drive.
* Come back and connect your OP2 to the PC and examine the CSV files…”
But after I install, my openport wont work, sometimes the ecuflash detect it but it said the log window like this:
[20:15:30.987] EcuFlash Version 1.42.2720
[20:15:30.987] OS Version Windows XP
[20:15:30.987] Qt Version 4.5.2
[20:15:31.065] 57 memory models read.
[20:15:31.065] scanning for metadata models in C:/Documents and Settings/eshendra/My Documents/EDWIN/TACTRIX/rommetadata
[20:15:39.834] 643 ROM metadata models scanned.
[20:15:39.834] checksum module "subarudbw" loaded.
[20:15:39.834] checksum module "mitsucan" loaded.
[20:15:39.834] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[20:15:39.834] flashing tool "wrx02" loaded.
[20:15:39.834] flashing tool "wrx04" loaded.
[20:15:39.834] flashing tool "sti04" loaded.
[20:15:39.834] flashing tool "sti05" loaded.
[20:15:39.834] flashing tool "mitsukernel" loaded.
[20:15:39.834] flashing tool "mitsukernelocp" loaded.
[20:15:39.834] flashing tool "mitsubootloader" loaded.
[20:15:39.834] flashing tool "shbootmode" loaded.
[20:15:39.881] flashing tool "shaudmode" loaded.
[20:15:39.881] flashing tool "subarucan" loaded.
[20:15:39.881] flashing tool "mitsucan" loaded.
[20:15:47.009] J2534 error [unable to open device].
[20:15:47.009] unable to connect to vehicle interface.
[20:15:47.009] interface close
even if I try to install the previous version of ecuflash, please give me advice to make my OP2.0 works again, thanks
