Postby freakin » Tue Dec 01, 2009 8:46 am
cboles, can you confirm the max length of a parameter please so i can prevent my app from making long strings
log parameter name too long at line 2
freakin
Postby paul_p1 » Tue Dec 01, 2009 12:47 pm
Hi, this seems to work for me when I first initiate the logging, i.e the first log file is complete, any subsequent files created are empty but have a file size greater than 0K, i.e 25K or 50K etc. When you try to open them Excel complains that they're not in a recognisable format. Has anyone else seen this issue?
paul_p1
Postby mohammadov » Fri Dec 04, 2009 8:59 am
Can anyone plz tell me why inno.afr numbers be like this?????i read before about LM Programmer,but i couldnt found it,what i installed in my laptop is Logwork2.0 and logworks 3.0 and i couldnt found something called LM Programmer.
PS:I have lc-1.
RPM      Ignition   Throttle   Mass      KC        FLKC            inno.afr
697      10.5      0      1.2      0      0                       5.1548
687.5   11.5      0      1.22      0      0                      5.1695
716      9      0      1.2      0      0                      5.1695
718.75   9      0      1.22      0      0                         5.1891
727.5   8.5      0      1.22      0      0                      5.194
729.5   9      0      1.2      0      0                          5.2283
727.25   9.5      0      1.24      0      0                      5.2185
730.25   9.5      0      1.22      0      0                      5.2283
738.25   9.5      0      1.22      0      0                      5.2087
721.25   11.5      0      1.24      0      0                      5.1646
724.5   11      0      1.2      0      0                      5.1989
725.75   11      0      1.2      0      0                      5.1352
717      12      0      1.2      0      0                       5.1352
706.25   13      0      1.22      0      0                      5.0764
703.25   13      0      1.2      0      0                      5.0666
677.25   15.5      0      1.22      0      0                      5.0666
THANX
mohammadov
Postby cboles » Fri Dec 04, 2009 9:44 am
The stoichiometric AFR value that inno.lambda is multiplied by that comes from your LC-1 is incorrect. For some reason, the LC-1 seems to lose this value sometimes. Solutions are:
1) Fix the value with the LC-1 tool
2) Create a calulated AFR parameter that is basically inno.lambda * AFRstoich, e.g. inno.lambda,14.7,*
3) I will be adding a new inno.afr147 parameter to the next release which is basically inno.lambda * 14.7
mohammadov wrote:Can anyone plz tell me why inno.afr numbers be like this?????i read before about LM Programmer,but i couldnt found it,what i installed in my laptop is Logwork2.0 and logworks 3.0 and i couldnt found something called LM Programmer.
PS:I have lc-1.
THANX
Postby cboles » Fri Dec 04, 2009 9:46 am
paul_p1 wrote:Hi, this seems to work for me when I first initiate the logging, i.e the first log file is complete, any subsequent files created are empty but have a file size greater than 0K, i.e 25K or 50K etc. When you try to open them Excel complains that they're not in a recognisable format. Has anyone else seen this issue?
Could you post your logcfg.txt and a couple of the bad files?
Postby mohammadov » Fri Dec 04, 2009 11:23 am
Thanx a lot cboles,i will try it and feedback.
cboles wrote:The stoichiometric AFR value that inno.lambda is multiplied by that comes from your LC-1 is incorrect. For some reason, the LC-1 seems to lose this value sometimes. Solutions are:
PS:I have lc-1.
THANX
mohammadov
Postby freakin » Sat Dec 05, 2009 2:53 am
Colby, any idea why this is happening
[A/F_Sensor_#1_(Direct)*(AFR),0,0.000000]
is too long
yet above on line 54 is longer but seems to pass
[Manifold_Absolute_Pressure_(Direct)*(psi_absolute),0,0.000000]
54: paramname = Manifold_Absolute_Pressure_(Direct)*(psi_absolute)
: name[paramname,16] value[Manifold_Absolute_Pressure_(Direct)*(psi_absolute),0,0.000000]
55: paramid = 0x2186A
: name[paramid,17] value[0x2186A,137322,0.000000]
56: databits = 16
: name[databits,22] value[16,16,16.000000]
57: scalingrpn = x,0.01933677,*
: name[scalingrpn,18] value[x,0.01933677,*,0,0.000000]
58: paramname = A/F_Sensor_#1_(Direct)*(AFR)
: name[paramname,16] value[A/F_Sensor_#1_(Direct)*(AFR),0,0.000000]
log parameter name too long at line 58
freakin
Postby cboles » Sat Dec 05, 2009 9:59 am
because you have really long parameter names :)
i made a single store for strings so that there is not really a limit on the string size for a single parameter, but you have an overall limit on the total size of all of these strings that you are running up against. better to keep them short...
freakin wrote:Colby, any idea why this is happening
is too long
56: databits = 16
Postby chaeoz » Sun Dec 06, 2009 8:04 am
Still no luck.
Testing with another OP2.0 and the values are still 0, so I'm guessing that the cable is flaky. Tried jiggling, etc... Not much help.
Problem is, the innovate connector is pretty painful. Self fabricated plugs do not fit, as it is a slight rubber protrusion.
I may have to order a proper MTS cable, no?
cboles wrote:One thing to watch out for is that I have found that the Innovate 2.5mm connectors can be a bit flaky on the Innovate side - try jiggling them a bit just in case.
chaeoz wrote:LC-1 logging configuration is definitely set up correctly, there is a column inside the log file with the header, inno.afr, but the values are all 0.
I have tested my 2.5mm <-> 2.5mm cable with a multimeter, the connection is fine.
LC-1 logging is definitely okay, I've been logging with a laptop and it is fine. Now, I want to get my hands on another OP2.0 to ensure that it is not a OP2.0 problem.
chaeoz
Postby mohammadov » Sun Dec 06, 2009 8:53 am
I never found 2.5mm to 2.5 mm cable,so i bought conversion connectors from 3.5 to 2.5 and about 3.5<-->3.5 cable which i found,
Now i faced a problem of the innovate OUT cable,which has rubber and the hole is too small,i cut some of that innvoate cable rubber,and inserted my fabricated cable,and it start reading.
chaeoz wrote:Still no luck.
mohammadov
Postby Paul R » Mon Dec 07, 2009 1:39 pm
Just thought I'd update the thread with some findings after using it for a few days, logging works great on an Evo VI with the pin 1 to ground config setting, the speed calc might be out slightly though which shows a max of 55mph but was checked on GPS at 75mph (speedo was showing just under 80mph).
One side-affect is the central locking toggles about 2 seconds after switching the ignition off, could very well be the alarm, no idea.
Thank you :D
Paul R
Postby cboles » Mon Dec 07, 2009 1:43 pm
glad to hear it!
Paul R wrote:Just thought I'd update the thread with some findings after using it for a few days, logging works great on an Evo VI with the pin 1 to ground config setting, the speed calc might be out slightly though which shows a max of 55mph but was checked on GPS at 75mph (speedo was showing just under 80mph).
Thank you :D
Postby mshoemaker » Thu Dec 10, 2009 3:48 am
I just put the suburu-can.txt file out of the logging sample directory on my OP2, renamed to logcfg.txt, and tried it out this morning and I get the same result. I do not get any flashing lights, and all I get on the memory card is an empty logcfg.out file. I have not tried setting it to use k-line logging, but I will try that this evening. Any other suggestions?
Matthew
mshoemaker wrote:I just applied the patch to my 09 WRX to enable the RAM parameter logging, but now when I connect my OP2 and start the car I get nothing but an empty logcfg.out file. I think the logcfg file worked previously doing k-line logging, and all I did was change the type at the top of the file back. I could be wrong however because it has been about a month since I last tried the stand alone logging. I am at work currently and can not check my file or verify anything, but thought I would ask if anyone has ideas where I should look first.
Matthew
mshoemaker
Postby cboles » Thu Dec 10, 2009 10:50 am
What size / make is the SD card? What filesystem is it formatted with (FAT16, FAT32, etc)? I'm wondering if the OP2 is having some trouble writing to that card for some reason.
mshoemaker wrote:I just put the suburu-can.txt file out of the logging sample directory on my OP2, renamed to logcfg.txt, and tried it out this morning and I get the same result. I do not get any flashing lights, and all I get on the memory card is an empty logcfg.out file. I have not tried setting it to use k-line logging, but I will try that this evening. Any other suggestions?
Matthew
Matthew
Postby mshoemaker » Thu Dec 10, 2009 10:57 am
The card is a 2GB Sandisk, formatted fat32, and while it is very possible that it is an issue with the card, it was working before applied the patch. I will try reformatting the card on a different computer and try it again if the k-line logging doesn't work. After that perhaps I can re-flash with an unpatched ROM.
Matthew
cboles wrote:What size / make is the SD card? What filesystem is it formatted with (FAT16, FAT32, etc)? I'm wondering if the OP2 is having some trouble writing to that card for some reason.
mshoemaker
