I've since set it back to 14.7 Gasoline and get good logs from the OP2
I have a digital panel meter hooked into Analog #2 Output and have always had reliable AFR readings. Because of this I wasn't suspecting the LC-1 controller's configuration
cboles wrote:I'm looking into it, but I've had a couple of sensor failures on the bench... Keep in mind that the OP2 cacluates the AFR based on the AFR multiplier that the LC-1 provides. If you go into the LC-1 configuration tool and find that this is not set to 14.7 (or whatever is right for your fuel) - then this is the reason your AFRs are bad. I have seen the LC-1 loose this information before - I'm not sure why it does it. You could always make a calculated parameter that does the multiply, or I could make a hard-wired inno.afr147 parameter as well.ladams00 wrote:mdedwar wrote:
This looks like the problem I have.
This did work for me under an older version.
Agreed LC-1 AFR's logged accurately in an earlier version. I however no longer have the logs to confirm.
