Postby cboles » Sun Oct 25, 2009 5:04 pm
I hear you on the OSX library. My dev Mac kicked the bucket a couple of weeks back and I need to fix the power supply to get back to that machine. I should be set up for a pretty quick port of op20pt32.dll though. The only big issue on OSX at the moment is that there is some goofiness with USB composite devices that have communication device class (CDC) devices as one of the devices. This means that you can't have the SD card plugged in and have the OP2 work on a Mac right now. I have someone at Apple that has already made a fix to their CDC driver, but it never seems to make it into any of their releases.
...and yes, you can operate all physical buses on the OP2 simultaneously. You can even tee CAN and ISO15765 data and analyze it via both protocols as well.
altaic wrote:
cboles wrote:It's entirely *possible* to do, it's just a very low priority for me considering all of the other things I need to be doing, including the logging GUI features of EcuFlash. I have already written a sample CAN logger for the PC in the DLL distribution which works well - In fact I use it quite often. I think yours is a pretty execptional case where you are trying to CAN log without someone knowing. In all other cases, it is preferrable to have a laptop in front of you to be sure you are getting the data you want. Make friends with a service dept. and they will let you log while they do the work...
I know the service dept. pretty well, and they are cool with me, but I'd feel like I was imposing if I asked to log their session. Plus, they might be worried about damaging their SSM3/laptop/whatever by connecting it in parallel with an unknown device. I know it would be fine, but it seems like it's asking a lot.
Do you know if your CAN logger in the DLL distribution compiles on mac os x, or does it require the windows library? EDIT: After looking at it, it seems that it is dependent on the windows dll after all. At this point, I'd like to make my request for either the ability to sniff/dump to the microsd card, or mac os x support for the J2534 library. :(
Also, is it possible to dump both the CAN bus and K Line simultaneously? I don't know which they use for TPMS setup.
Thanks,
Will
Postby mdedwar » Sun Oct 25, 2009 6:14 pm
Hi Colby,
On my setup I find that I have to remove the SD card to allow for programs like ECUflash and RomRaider to talk to the ECU.
Is this supposed to be the case or should I be able to leave the SD card in and still connect with these programs?
Cheers,
Matt.
mdedwar
Postby Tephra » Sun Oct 25, 2009 6:35 pm
^ leaving the SD card in works for me.
Tephra
Postby mdedwar » Sun Oct 25, 2009 7:55 pm
Tephra wrote:^ leaving the SD card in works for me.
It occasionally worked for me under a previous version but no luck under the latest release.
mdedwar
Postby cboles » Sun Oct 25, 2009 11:12 pm
Interesting. It has always worked for me either way long before I ever released the OP2. What OS are you using? If it is XP, what is the version information on usbser.sys and usbccgp.sys? There were many problems with the early versions of both of those MS drivers, but EcuFlash should update them during install.
Postby mdedwar » Mon Oct 26, 2009 12:09 am
Hi Colby,
OS is win xp service pack 3 with usb version:
usbser.sys 5.1.2600.5512
usbccgp.sys 5.1.2600.5508
I'm using a usb to serial device for my lc-1 so it may be causing the problems or one of those great xp features.
mdedwar
Data overflow / corruption issue?
Postby bydant » Tue Oct 27, 2009 4:13 pm
]I have been using the standalone logging for the last month or so, and its a fantastic tool!
The car I am using it on is a MY01 ADM Forester GT (ECU ID: 2354500405 Internal ID: A4SE700F).
In the last couple of days I have decided to add my LC-1 to the logging but this has yielded some strange results:
sample   time   RPM   FuelBase   Load   FLKC   FBKC   CLOL   AF1   inno.afr
1948   403.09381   3742.25   10.81767876   1.862548828   0   0   36   11.2546875   4
1949   403.29381   3877.75   10.60803383   2.047180176   0   0   36   11.2546875   4
1955   404.49381   12511.25   0.917909629   1.531494141   -18.6328125   4.921875   16   21.01640625   140
1956   404.69381   1952   0.917909629   1.531494141   -17.578125   32.34375   16   3.10078125   129
1957   404.89381   7520   0.917881643   1.531494141   -17.578125   32.34375   12   9.1875   17
1958   405.09381   13792   0.917881643   1.718994141   -17.2265625   39.0234375   14   0   16
In this snippet of the log you can see that at sample 1949 all is ok, then 5 samples are dropped, and everything comes back all screwed up.
Here is the complete log:
log0001.csv
No conversion is done here. I do all conversions in excel
(327.49 KiB) Downloaded 1008 times
Here is the CSV with conversions:
Log0001.Converted.csv
Converted data
(505.43 KiB) Downloaded 929 times
Here is the output file:
logcfg.out.txt
out file
(3.67 KiB) Downloaded 967 times
Here is the Config file (all parameters are output as x without conversion):
logcfg.txt
Config file
(625 Bytes) Downloaded 994 times
This was never an issue until I hooked up the LC-1. I even had a log where I had the parameter added but didn't have the LC-1 plugged into the tactrix unit and all was fine over a 40 minute drive.
If any more information is required I am happy to provide.
bydant
Re: Data overflow / corruption issue?
Postby cboles » Tue Oct 27, 2009 4:25 pm
I will take a look at it. I know there is a bug currently where the sample count will increase by more than one per interval due to the additional LC-1 data, but that bug is minor and should not affect the actual data nor the timestamps and sampling. Unfortunately I don't have a LC-1 installed in my 2008 STi at the moment, so I am not getting a lot of real world testing here on this feature.
bydant wrote:]I have been using the standalone logging for the last month or so, and its a fantastic tool!
log0001.csv
logcfg.out.txt
logcfg.txt
Postby bydant » Tue Oct 27, 2009 4:27 pm
I am happy to help out if LC-1s are in demand.
bydant
Postby cboles » Tue Oct 27, 2009 4:31 pm
5512 is the correct build for XPSP3. I am not sure why your usbccgp.sys is not 5512. I checked my copy of usbccgp.sys on XPSP3 and it is 5512. When you have the OP2 plugged in, does your system show and additional COM port in device manager? Keep in mind that the OP2 uses a different PID when you plug it in with a SD card, so you have to go through a second driver installation cycle for this configuration. It is possible that you have a good driver install for the cardless OP2 config, but not the carded one.
mdedwar wrote:Hi Colby,
Postby mdedwar » Tue Oct 27, 2009 7:01 pm
Since using the stand alone logging I have had to recalibrate the LC-1 twice as the LC-1 started showing weird values even through the logworks software. Not sure if this is a problem with pluging it in to the tactrix cable and it randomly reseting the LC-1 or some other problem with the LC-1 (eg lose wire somewhere). However when it is calibrated it has worked fine.
Cheers,
Matt.
mdedwar
Postby mdedwar » Tue Oct 27, 2009 7:04 pm
cboles wrote:5512 is the correct build for XPSP3. I am not sure why your usbccgp.sys is not 5512. I checked my copy of usbccgp.sys on XPSP3 and it is 5512. When you have the OP2 plugged in, does your system show and additional COM port in device manager? Keep in mind that the OP2 uses a different PID when you plug it in with a SD card, so you have to go through a second driver installation cycle for this configuration. It is possible that you have a good driver install for the cardless OP2 config, but not the carded one.
I'll try and update usbccgp.sys to 5512 as it may be a driver conflict.
mdedwar
Postby mdedwar » Wed Oct 28, 2009 2:53 am
I updated usbccgp to 5512 and now it works as it should. Thanks for pointing me in the right direction.
Cheers,
Matt.
mdedwar
Postby dolphin » Wed Oct 28, 2009 7:24 am
Finally I made a progress :lol: I'm getting logcfg.out file and many *.cdv files, but what is wrong with them? Why data is so ruined? Check out RPM, TPS, SPEED :?
log0005.csv
csv files, check out my data
(36.35 KiB) Downloaded 922 times
OUT file log is below:
01: type=mut2
  : name[type,8] value[mut2,0,0.000000]
02: baud=62500
  : name[baud,10] value[62500,62500,62500.000000]
03: paramname=RPM
  : name[paramname,16] value[RPM,0,0.000000]
04: paramid=0x21
  : name[paramid,17] value[0x21,33,0.000000]
05: scalingrpn=x,31.25,*
  : name[scalingrpn,18] value[x,31.25,*,0,0.000000]
06: paramname=TPS
  : name[paramname,16] value[TPS,0,0.000000]
07: paramid=0x17
  : name[paramid,17] value[0x17,23,0.000000]
08: scalingrpn=x,0.39215686,*
  : name[scalingrpn,18] value[x,0.39215686,*,0,0.000000]
09: paramname=ECULoad
  : name[paramname,16] value[ECULoad,0,0.000000]
10: paramid=0x1C
  : name[paramid,17] value[0x1C,28,0.000000]
11: scalingrpn=x,0.625,*
  : name[scalingrpn,18] value[x,0.625,*,0,0.000000]
12: paramname=KnockSum
  : name[paramname,16] value[KnockSum,0,0.000000]
13: paramid=0x26
  : name[paramid,17] value[0x26,38,0.000000]
14: priority=2
  : name[priority,19] value[2,2,2.000000]
15: paramname=Speed
  : name[paramname,16] value[Speed,0,0.000000]
16: paramid=0x2F
  : name[paramid,17] value[0x2F,47,0.000000]
17: scalingrpn=x,1.242742384,*
  : name[scalingrpn,18] value[x,1.242742384,*,0,0.000000]
18: paramname=Knock
  : name[paramname,16] value[Knock,0,0.000000]
19: paramid=0x30
  : name[paramid,17] value[0x30,48,0.000000]
20: paramname=AirTemp
  : name[paramname,16] value[AirTemp,0,0.000000]
21: paramid=0x3A
  : name[paramid,17] value[0x3A,58,0.000000]
22: priority=2
23: conditionrpn=RPM,1800,>
  : name[conditionrpn,48] value[RPM,1800,>,0,0.000000]
24: action=start
  : name[action,49] value[start,0,0.000000]
25: conditionrpn=RPM,1800,<
  : name[conditionrpn,48] value[RPM,1800,<,0,0.000000]
26: action=stop
  : name[action,49] value[stop,0,0.000000]
--- log config dump ---
channel type: mut2
protocol id: 3
baud: 62500
param name: RPM
param id: 0x00000021
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,31.250000,*
param name: TPS
param id: 0x00000017
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,0.392157,*
param name: ECULoad
param id: 0x0000001C
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,0.625000,*
param name: KnockSum
param id: 0x00000026
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 1
scaling: x
param name: Speed
param id: 0x0000002F
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x,1.242742,*
param name: Knock
param id: 0x00000030
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x
param name: AirTemp
param id: 0x0000003A
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 1
scaling: x
trigger action: start condition: RPM,1800.000000,>
trigger action: stop condition: RPM,1800.000000,<
--- storage info ---
log stringlist: 71 chars
log floatlist: 5 floats
logging interval will be 50000us
dolphin
Postby cboles » Wed Oct 28, 2009 7:52 am
I haven't tested 62500 baud here. There may be a problem with the response bytes being considered part of the request because they come back very close in time to the request. What ECU is this Evo 7/8/9? I'll try patching the ROM for 62500 and check it out. Have your tried 15625 baud (standard)? Does that work?
dolphin wrote:Finally I made a progress :lol: I'm getting logcfg.out file and many *.cdv files, but what is wrong with them? Why data is so ruined? Check out RPM, TPS, SPEED :?
log0005.csv
01: type=mut2
02: baud=62500
03: paramname=RPM
04: paramid=0x21
06: paramname=TPS
07: paramid=0x17
10: paramid=0x1C
13: paramid=0x26
14: priority=2
15: paramname=Speed
16: paramid=0x2F
18: paramname=Knock
19: paramid=0x30
21: paramid=0x3A
22: priority=2
24: action=start
26: action=stop
channel type: mut2
protocol id: 3
baud: 62500
param name: RPM
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
param name: TPS
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
param name: ECULoad
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 1
scaling: x
param name: Speed
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
param name: Knock
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 0
scaling: x
param name: AirTemp
read width: 1 bytes
data width: 8 bits
data offset: 0 bits
float: 0
low priority: 1
scaling: x
