8MR JDM
8MR JDM
Postby S54fan » Sun Sep 10, 2006 9:44 am
Put the xmls in program files/ecuflash/rommetadata/mitsubishi/evo/
On is for FQ300/8 non-MR, and the other is 8MR which inherits it.
I intentionally mislabelled the wastegate duty maps as there as 7 of them - 4 are at 100%, I show 1 of these only as #1, and the others as
2,3,4. 2,3,4 are the ones to change to raise boost.
WG tables:
4116, 412c, 4142, 4158, 416e, 4184, 419a
(2 solenoids, the 100% ones are for one solenoids, the non-100% ones for the other, set the non-100% ones the same when altering).
93660005.xml
(5.26 KiB) Downloaded 1096 times
96260007.xml
(1.97 KiB) Downloaded 1067 times
ROM
Postby S54fan » Sun Sep 10, 2006 9:46 am
ROM
JDM-E8MR.zip
(108.46 KiB) Downloaded 647 times
Postby nvr2fast » Tue Sep 12, 2006 7:50 pm
Good contribution! :D 8)
nvr2fast
Re: ROM
Postby spooky » Thu Sep 14, 2006 12:15 pm
i did what you instructed but the high octane ignition map 1 doesnt appears...can you assist on this?
thanks!!!
spooky
Postby S54fan » Thu Sep 14, 2006 12:33 pm
It seems that people have trouble getting ECUflash to work with xml files. Without a detailed how-to on the subject, it is difficult to identify what problems people are having. Also, saving an xml from one machine and transferring its function to another seems to depend on what xmls are on the other machine and if the base files have been changed.
It is however relatively straightforward to load up the ROM without the xml files and get it to inherit Evo9 base, define a dummy map of location 0 with axes 0 and 0 and then save models. Then manually edit the xml file to match the main details of what I posted.
Users browsing this forum: No registered users and 14 guests
