by burgers » Mon Sep 18, 2006 11:07 am
Hi
Each ROM file needs to be associated with a deffinition file. The developers of ECUflash have included some deffinition files, but they need the ROM image to work from, which they may not have. Also it can be quite a bit of work to get a good deffinition file, either by disasembly, or work in a hex tool. I trust you understand that this free software will need a bit of work from your side.
You may be able to read the ROM image by associating it with a definition file that is close in year to yours. If you post up the code from the out side of the ECU, tell us the model and year of the car, then members here maybe able to help you indentify a good def. file.
MB
