XML definitions Wrong For EVO 8 - 93660005
Postby andy.uk » Sat Aug 19, 2006 1:30 am
IF somebody could please have a look at the atached ROM
and XML def.
When i read the IGN Maps they are incorrect and some of the other maps are not showing.
I can only assume that the XML Def i have is either wrong, old or something.
Has any body else got a better XML Def for a 93660005 EVO 8 ROM
THANKS
93660005.xml
(4.31 KiB) Downloaded 667 times
EVO8_ROM.bin
(256 KiB) Downloaded 666 times
andy.uk
Postby S54fan » Sat Aug 19, 2006 3:17 am
Hi Andy,
I looked through your ROM with ECUedit's hex editor.
Your ignition maps are 19*19 and the addresses have been changed in the xml file attached. I've not changed the RPM scaling for them, so that still needs work.
You have all you need to go here if using external boost control I reckon.
Is this a UK FQ VIII MR? I've been interested for a while to see the contents of the VIII MR's ECU with the debate on the MLR about the 340's Unichip etc.
Cheers,
John Banks
SEE NEW ATTACHMENT IN NEXT POST
New version xml
Postby S54fan » Sat Aug 19, 2006 7:36 am
New version of xml after a lot more editing.
Now has turbo dynamics, wastegate duty, boost targets, correct load and RPM scaling for ignition maps.
Would really like to know if this is an MR model or a plain VIII...
93660005.xml
(5.26 KiB) Downloaded 820 times
Q About model
Postby andy.uk » Wed Aug 23, 2006 1:46 am
This map is for the JDM spec EVO 8
Not the MR Model.
andy.uk
Postby S54fan » Wed Aug 23, 2006 1:58 am
OK, hope it helps you anyway :)
I thought it wasn't with the single wastegate solenoid.
