JDM Evo VII GSR
JDM Evo VII GSR
Postby R. Mutt » Sun Jul 16, 2006 3:42 pm
Stock rom
Duane.hex
(256 KiB) Downloaded 802 times
R. Mutt
Postby burgers » Mon Jul 17, 2006 1:34 pm
Hi
Looks to be the same as the one I posted in your other thresd about JDM Evo VII.
MB
burgers
Postby R. Mutt » Mon Jul 17, 2006 7:37 pm
I haven't compare them yet, but I wouldn't doubt. What I'm curious about is the stationary rev limit parameter. It's set to 5000, but the JDM evo's here (Trinidad) can rev over 5000 rpm from a stand still. I don't understand why it's there.
R. Mutt
Postby mlr » Tue Jul 18, 2006 2:32 am
Stationary rev limit work on evo8 - when U press the clutch.
I made experiment with evo 7 ralliart ecu installed in evo8 - similar to evo7 jdm- stationary rev limit seems non working...
If U dont have the clutch swith - it wont work.
mlr
Postby R. Mutt » Wed Jul 19, 2006 3:18 pm
Thanks for the reply. :D How much for this clutch switch? Anything else needed to get this feature to work?
R. Mutt
I dont think i'll help.
Postby mlr » Thu Jul 20, 2006 10:58 pm
I have evo8 and i'm running it with evo8 stock ecu end evo7 rallart ecu-
on evo 8 it works
on evo7ra-dont.:(
The wiring is the same.
I dont know exactly if it doesnt work on evo7 non ralliart ecu.
http://www.roadraceengineering.com/evo/ ... wiring.htm
Before bying the switch U should start from playing with clutch position switch input-if it will start working - than evo7 supports it as hidden feature....
mlr
