'05'EVO VIII stock rom
Postby golruss » Fri Jun 09, 2006 7:20 pm
Here is a copy of my stock rom.
read image stock 05 evo 5_26_06.hex
(256 KiB) Downloaded 949 times
golruss
Postby papitoevo8 » Wed Aug 09, 2006 3:36 pm
Looking at your map, it differs from other 05 stock maps
papitoevo8
Postby radsdau » Wed Aug 09, 2006 3:59 pm
Is this a US ROM?
evo 05 map
Postby golruss » Wed Aug 09, 2006 5:11 pm
This is a stock US map.
golruss
Postby papitoevo8 » Wed Aug 09, 2006 7:14 pm
What is the built date on your evo 8? Just comparing different 05 stock maps. Your stock map felt more responsive on my ecu. It seems like there is different variations of the 05 stock map.
papitoevo8
Postby BlackVIII » Thu Aug 10, 2006 4:25 pm
I also have an '05, and in your "stock" ROM the "boost limit" is set to "319" throughout the entire rev range. Whereas in my stock ROM it's set to "245" and tapers to "225" as revs rise.
The fuel and ignition maps do match my stock ROM exactly though.
BlackVIII
05 EVO Map correction
Postby golruss » Mon Aug 14, 2006 4:28 pm
Sorry I took so long to respond, I may have made a mistake with the MAP I uploaded, I did change the boost limit to 319 (27PSI I believe) otherwise the map is stock. Sorry again for the mix-up.
Car is dated November 2004.
golruss
Postby Milburn » Sat Aug 26, 2006 10:52 am
Golruss: I am new to reading and logging ROM data. I downloaded and installed Ecuflash 1.28 and also downloaded your stock 05 ROM. Placed in the rom directory but Ecuflash doesnt seem to find it. I confirmed it is a hex file and it is there under Explorer . Nothing in Ecuflash.
It is a stupid question but how do I get it to load into EcuFlash? i want to compare it to my 05 MR ( Mar 05 builddate ) ROM. Then once Ive learned enough, log some runs and make minor changes, comparing to yours.
Any help much appreciated
Milburn
Milburn
Postby golruss » Sat Aug 26, 2006 6:46 pm
Hi just place the file somewhere convenient (like on your desktop) it should be a Hex file, then open ECUFLASH, go to file OPEN ROM a window should pop-up and you will see LOOK IN (thats asking for the location you where you saved the file eg. desktop) find the file and click open.
I think thats all.
golruss
Users browsing this forum: No registered users and 40 guests
