hi guys,
i have 2 Qs..
1st: can i use the ecuflash in a evo6 rs for a reflash?
and
2nd: from where i can buy this cable i need??? i think that the evo6 has only the obd2 port and not the second smaller one i'm seen in the fotos for the 7-8-9 evos.. but i might be wrong...
i'm asking because i cant connect to my car any of my obd2 loggers (pocketloger,auterra) because it seems that there is something different in the ecu interface compared to the other newer evos in witch i can connect pretty easy... (the same thing happens if i try to connect them to a subaru gt..)
the only thing that connects to the evo 6 in order to read the cel codes and for general diagnostics is the official mitsubishi dealers MUT-II scan tool as they call it...
i hope that you can help me 'cause i'm pretty exited with the reflash idea!
thank you all in advance!
