ECUFlash Rom table Help??
Postby c-spec » Thu May 25, 2006 6:31 pm
cboles wrote:for everyone:
keep in mind that every time you install ecuflash, your current rommetadata gets copied to a backup directory and replaced by the rommetadata in the install.
this allows me to deliver new updated definitions to you without deleting anything you might have done on your own. you will have to manually merge your work to combine definitions in the same XML file though.
another alternative (which i use) is to keep my rommetadata in a different directory (which can be setup from the options). this way new installations don't effect my definitions, but i can switch at will by changing the dir in the options and restarting the program.
colby
that's what i did :D
c-spec
