ECU FLASH ROM LANCERBACE PROBLEM
Postby azntuning » Sun Feb 24, 2013 9:36 am
Hi ecu flash all .
There i got the problems from tuning software.
When open the file than can not find the lancerbase.
So i cant open the maps for the tuning.
Please help me .
Rom info
Mitsubishi /Lancer/EX/CHINA/CVT
Internal ID:54990003 / Inherits:54730003
[23:36:54.030] EcuFlash Version 1.44.3719
[23:36:54.030] OS Version Windows 7
[23:36:54.030] Qt Version 4.8.0
[23:36:54.046] 63 memory models read.
[23:36:54.046] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[23:36:54.248] 613 ROM metadata models scanned.
[23:36:54.248] checksum module "subarudbw" loaded.
[23:36:54.248] checksum module "mitsucan" loaded.
[23:36:54.248] checksum module "mitsuh8" loaded.
[23:36:54.248] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[23:36:54.248] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[23:36:54.264] flashing tool "wrx02" loaded.
[23:36:54.264] flashing tool "wrx04" loaded.
[23:36:54.264] flashing tool "sti04" loaded.
[23:36:54.264] flashing tool "sti05" loaded.
[23:36:54.264] flashing tool "mitsukernel" loaded.
[23:36:54.264] flashing tool "mitsukernelocp" loaded.
[23:36:54.264] flashing tool "mitsubootloader" loaded.
[23:36:54.264] flashing tool "shbootmode" loaded.
[23:36:54.264] flashing tool "shaudmode" loaded.
[23:36:54.264] flashing tool "subarucan" loaded.
[23:36:54.280] flashing tool "subarucand" loaded.
[23:36:54.280] flashing tool "mitsucan" loaded.
[23:36:57.259] Unable to find parent metadata lancerbase
[23:36:57.259] 54990003 (0 tables) inheriting 54730003 (53 tables)
[23:36:57.259] using metadata XML ID 54990003 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/mitsubishi/lancer/54990003.xml
which inherits XML ID 54730003 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/mitsubishi/lancer/54730003.xml
[23:36:57.275] 1048576 byte image read.
azntuning
Re: ECU FLASH ROM LANCERBACE PROBLEM
Postby todd-w » Thu Feb 28, 2013 5:49 am
found this attached
lanceratbase.xml
(231 Bytes) Downloaded 1014 times
todd-w
