2012 Lancer MT 2.0 - Def File 57750003
Postby wcgomes » Thu Jan 03, 2013 8:44 am
Hi,
I already have a xml def file for 57750003 but only with the <romid> area. It's all that I need to reflash my ROM but I couldn't find a more complete def file containing all def tables, scales or more to be able to take a look on ROM parameters.
Here's my current def file:
<rom>
   <romid>
      <xmlid>5775</xmlid>
      <internalidaddress>5002e</internalidaddress>
      <internalidhex>57750003</internalidhex>
      <caseid>1860B747</caseid>
      <ecuid>SM5084</ecuid>
      <make>Mitsubishi</make>
      <market>Brazil</market>
      <model>Lancer</model>
      <submodel>MT</submodel>
      <transmission>5MT</transmission>
      <year>2012</year>
      <flashmethod>mitsucan</flashmethod>
      <memmodel>M32186F8</memmodel>
      <checksummodule>mitsucan</checksummodule>
   </romid>
</rom>
I already tried some mixing with some xml file in rommetadata folder but with no success.
Thanks in advance for any help!
2012-lancer-mt-stock.bin
(1 MiB) Downloaded 1103 times
wcgomes
Re: 2012 Lancer MT 2.0 - Def File 57750003
Postby wcgomes » Fri Jan 04, 2013 2:27 am
After some research over the internet I could get some tables from other def files and put it in mine.
Most tables "looks" fine, or at least better than previous tries, by the way, I really new on this so I'm really not sure about it.
I'll be very glad if anyone can confirm if these tables are correct for my ROM file.
<rom>
   <romid>
      <xmlid>5775</xmlid>
      <year>2012</year>
   </romid>
   <scaling name="AFR" units="AFR" toexpr="14.7*128/x" frexpr="14.7*128/x" format="%.1f" min="8" max="20" inc="0.1" storagetype="uint8" endian="big"/>
   <scaling name="BatteryVoltage" units="V" toexpr="x*75/1023" frexpr="x*1023/75" format="%.2f" min="0" max="18.75" inc="0.5" storagetype="uint16" endian="big"/>
   <scaling name="BoostErrorPsi" units="psi" toexpr="(x-128)*0.19347/4" frexpr="(x*4/0.19347)+128" format="%.1f" min="-6.1" max="6.1" inc="0.1" storagetype="uint16" endian="big"/>
   <scaling name="DynamicBoost" units="%" toexpr="(x-128)/2" frexpr="x*2+128" format="%.1f" min="-64" max="63.5" inc="0.5" storagetype="uint8" endian="big"/>
   <scaling name="ECU ID" units="units" toexpr="x" frexpr="x" format="%08x" min="0" max="1e+08" inc="1" storagetype="uint32" endian="big"/>
   <scaling name="EngineTorque" units="units" toexpr="x*3" frexpr="x/3" format="%.0f" min="0" max="510" inc="1" storagetype="uint8" endian="big"/>
   <scaling name="Hex16" units="hex" toexpr="x" frexpr="x" format="%04X" min="0" max="65535" inc="1" storagetype="uint16" endian="big"/>
   <scaling name="Hex8" units="hex" toexpr="x" frexpr="x" format="%02X" min="0" max="255" inc="1" storagetype="uint8" endian="big"/>
   <scaling name="IgnitionCompensation" units="x" toexpr="x-128" frexpr="x+128" format="%.0f" min="-128" max="128" inc="1" storagetype="uint8" endian="big"/>
   <scaling name="InjectorLatency" units="ms" toexpr="x*0.015" frexpr="x/0.015" format="%.3f" min="0" max="4" inc="0.015" storagetype="uint8" endian="big"/>
   <scaling name="InjectorLatency_old" units="ms" toexpr="x*0.024" frexpr="x/0.024" format="%.3f" min="0" max="4" inc="0.024" storagetype="uint8" endian="big"/>
   <scaling name="InjectorScaling" units="cc/min" toexpr="29241/x" frexpr="29241/x" format="%.0f" min="1" max="1000" inc="10" storagetype="uint16" endian="big"/>
   <scaling name="LT Trim Hz" units="Hz" toexpr="x*6.25" frexpr="x/6.25" format="%.2f" min="0" max="1593.75" inc="6.25" storagetype="uint8" endian="big"/>
   <scaling name="Load" units="%" toexpr="x*10/32" frexpr="x*32/10" format="%.0f" min="0" max="300" inc="1" storagetype="uint16" endian="big"/>
   <scaling name="Load16" units="load" toexpr="x*5/8" frexpr="x*8/5" format="%.1f" min="0" max="100" inc="1" storagetype="uint16" endian="big"/>
   <scaling name="Load8" units="%" toexpr="x*5/8" frexpr="x*8/5" format="%.1f" min="0" max="160" inc="1" storagetype="uint8" endian="big"/>
   <scaling name="LoadBoost" units="%" toexpr="x*5/4" frexpr="x*4/5" format="%.0f" min="0" max="319" inc="1" storagetype="uint8" endian="big"/>
   <scaling name="LoadError" units="load" toexpr="x*5/32-20" frexpr="(x+20)*32/5" format="%.1f" min="-20" max="20" inc="0.5" storagetype="uint16" endian="big"/>
   <scaling name="Loadify" units="%" toexpr="(x*10/512)*10/32" frexpr="(x*32/10)*512/10" format="%.1f" min="0" max="300" inc="1" storagetype="uint16" endian="big"/>
   <scaling name="MIVECInterpolation" units="% Normal Temp Map" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="100" inc="2" storagetype="uint8" endian="big"/>
   <scaling name="MUT32" units="hex" toexpr="x" frexpr="x" format="%06X" min="0" max="1e+08" inc="1" storagetype="uint32" endian="big"/>
   <scaling name="Min timing" units="degrees" toexpr="x-20" frexpr="x+20" format="%.0f" min="-61" max="61" inc="1" storagetype="int8" endian="big"/>
   <scaling name="OffsetWGDC" units="%WGDC Change" toexpr="(x-128)/2" frexpr="x*2+128" format="%.1f" min="-64" max="63.5" inc="0.1" storagetype="uint8" endian="big"/>
   <scaling name="Percent128" units="%" toexpr="x*100/128" frexpr="x*128/100" format="%.1f" min="80" max="105" inc="0.1" storagetype="uint8" endian="big"/>
   <scaling name="Percent255" units="%" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="100" inc="2" storagetype="uint8" endian="big"/>
   <scaling name="RPM" units="RPM" toexpr="x*1000/256" frexpr="x*256/1000" format="%.0f" min="0" max="11000" inc="50" storagetype="uint16" endian="big"/>
   <scaling name="RPM8" units="RPM" toexpr="x*125/16" frexpr="x*16/125" format="%.0f" min="0" max="2000" inc="50" storagetype="uint8" endian="big"/>
   <scaling name="RPMLimit" units="RPM" toexpr="7500000/x" frexpr="7500000/x" format="%.0f" min="0" max="9000" inc="60" storagetype="uint16" endian="big"/>
   <scaling name="RPMPerMPH" units="RPM/MPH" toexpr="x/22.6" frexpr="22.6*x" format="%.0f" min="0" max="3000" inc="5" storagetype="uint16" endian="big"/>
   <scaling name="RPMStatLimit" units="units" toexpr="x*31.25" frexpr="x/31.25" format="%.0f" min="0" max="9000" inc="31.25" storagetype="uint16" endian="big"/>
   <scaling name="RPMTarget" units="RPM" toexpr="x*125/16" frexpr="x*16/125" format="%.0f" min="0" max="2000" inc="50" storagetype="uint16" endian="big"/>
   <scaling name="StockXMAP in psig" units="StockXMAP in psig" toexpr="((x/4)*0.19347)-14.5" frexpr="((x+14.5)/0.19347)*4" format="%.2f" min="-15" max="35" inc="0.05" storagetype="uint16" endian="big"/>
   <scaling name="Temp" units="Celsius" toexpr="x-40" frexpr="x+40" format="%.0f" min="-40" max="215" inc="1" storagetype="uint16" endian="big"/>
   <scaling name="TempFarenheit" units="Farenheit" toexpr="1.8*x-40" frexpr="(x+40)/1.8" format="%.0f" min="-40" max="350" inc="1" storagetype="uint16" endian="big"/>
   <scaling name="Throttle %" units="%" toexpr="x*100/255" frexpr="x*255/100" format="%.1f" min="0" max="100" inc="2" storagetype="uint16" endian="big"/>
   <scaling name="Throttle Opening" units="%" toexpr="x/3277*100" frexpr="x/100*3277" format="%.1f" min="0" max="100" inc="0.5" storagetype="uint16" endian="big"/>
   <scaling name="ThrottleMAINorSUBInvertedOpening %" units="%" toexpr="100*(x-26)/(204)" frexpr="(x+26)/100*(204)" format="%.1f" min="0" max="100" inc="0.5" storagetype="uint16" endian="big"/>
   <scaling name="Throttle_Main - Stored Minimum Throttle %" units="%" toexpr="(x+(90/4))*100/255" frexpr="x*255/100-(90/4)" format="%.1f" min="0" max="100" inc="2" storagetype="uint16" endian="big"/>
   <scaling name="Time" units="ms" toexpr="x*25" frexpr="x/25" format="%.0f" min="0" max="1.63838e+06" inc="25" storagetype="uint16" endian="big"/>
   <scaling name="TimeInjCranking" units="ms" toexpr="x*0.005" frexpr="x/0.005" format="%.1f" min="0" max="500" inc="1" storagetype="uint16" endian="big"/>
   <scaling name="Timing" units="degrees" toexpr="x" frexpr="x" format="%.0f" min="-61" max="61" inc="1" storagetype="int8" endian="big"/>
   <scaling name="ValveTimingExhaust" units="degrees" toexpr="80-x*0.625" frexpr="(80-x)/0.625" format="%.1f" min="-35" max="0" inc="1" storagetype="uint8" endian="big"/>
   <scaling name="ValveTimingIntake" units="degrees" toexpr="80-x*0.625" frexpr="(80-x)/0.625" format="%.1f" min="10" max="35" inc="1" storagetype="uint8" endian="big"/>
   <scaling name="VehicleSpeed" units="km/h" toexpr="x*2" frexpr="x/2" format="%.0f" min="0" max="510" inc="1" storagetype="uint16" endian="big"/>
   <scaling name="VehicleSpeedFreq" units="km/h" toexpr="x*0.25" frexpr="x/0.25" format="%.1f" min="0" max="64" inc="0.2" storagetype="uint16" endian="big"/>
   <scaling name="VoltsADC1023" units="Volts" toexpr="x*5/1023" frexpr="x*1023/5" format="%.2f" min="0" max="5" inc="0.05" storagetype="uint16" endian="big"/>
   <scaling name="WGDuty" units="%" toexpr="x/2" frexpr="x*2" format="%.1f" min="0" max="100" inc="0.5" storagetype="uint8" endian="big"/>
   <scaling name="blobbits" storagetype="bloblist" storagebits="1">
      <data name="0" value="00"/>
      <data name="1" value="01"/>
   </scaling>
   <scaling name="psia16" units="psia" toexpr="x*0.19347" frexpr="x/0.19347" format="%.1f" min="0" max="49.5" inc="0.1" storagetype="uint16" endian="big"/>
   <scaling name="psia8" units="psia" toexpr="x*0.19347" frexpr="x/0.19347" format="%.1f" min="0" max="49.5" inc="0.1" storagetype="uint8" endian="big"/>
   <scaling name="uint16" units="units" toexpr="x" frexpr="x" format="%.0f" min="0" max="65535" inc="1" storagetype="uint16" endian="big"/>
   <scaling name="uint8" units="units" toexpr="x" frexpr="x" format="%.0f" min="0" max="255" inc="1" storagetype="uint8" endian="big"/>
   <table name="ECU ID" category="Misc" address="5002a" type="1D" scaling="ECU ID"/>
   <table name="IFMode 0x05->0x23 #1" category="Misc" address="7fafd" type="1D" level="1" scaling="Hex8"/>
   <table name="IFMode 0x05->0x23 #2" category="Misc" address="8aa79" type="1D" level="1" scaling="Hex8"/>
   <table name="DoMode 0x4B->0x5B" category="Misc" address="8aa82" type="1D" level="1" scaling="Hex16"/>
   <table name="High Octane Timing Map" category="Timing" address="55653" type="3D" level="4" swapxy="true" scaling="Timing">
      <table name="Load" address="5ead2" type="X Axis" elements="13" scaling="Load"/>
      <table name="RPM" address="5eaa4" type="Y Axis" elements="20" scaling="RPM"/>
   </table>
   <table name="Low Octane Timing Map" category="Timing" address="5575f" type="3D" level="4" swapxy="true" scaling="Timing">
   </table>
   <table name="Unknown Timing Map 1" category="Timing" address="5a793" type="3D" swapxy="true" scaling="Timing">
      <table name="Load" address="5ead2" type="X Axis" elements="12" scaling="Load"/>
      <table name="RPM" address="5eaa4" type="Y Axis" elements="16" scaling="RPM"/>
   </table>
   <table name="Unknown Timing Map 2" category="Timing" address="5a85b" type="3D" level="4" swapxy="true" scaling="Timing">
   </table>
   <table name="MIVEC Intake Normal Coolant Temp" category="Timing" address="5c16d" type="3D" swapxy="true" scaling="ValveTimingIntake">
      <table name="Load" address="5f10c" type="X Axis" elements="10" scaling="Load"/>
      <table name="RPM" address="5f126" type="Y Axis" elements="22" scaling="RPM"/>
   </table>
   <table name="MIVEC Intake Low Coolant Temp" category="Timing" address="5c251" type="3D" level="4" swapxy="true" scaling="ValveTimingIntake">
   </table>
   <table name="MIVEC Intake Map Interpolation" category="Timing" address="59ea2" type="2D" level="1" scaling="MIVECInterpolation">
      <table name="Coolant Temperature" address="5cf9a" type="Y Axis" elements="9" scaling="Temp"/>
   </table>
   <table name="MIVEC Exhaust Normal Coolant Temp" category="Timing" address="5c335" type="3D" swapxy="true" scaling="ValveTimingExhaust">
   </table>
   <table name="MIVEC Exhaust Low Coolant Temp" category="Timing" address="5c419" type="3D" swapxy="true" scaling="ValveTimingExhaust">
   </table>
   <table name="MIVEC Exhaust Map Interpolation" category="Timing" address="59eb0" type="2D" level="1" scaling="MIVECInterpolation">
   </table>
   <table name="Ignition Warmup Retard" category="Timing" address="56d23" type="3D" level="1" swapxy="true" scaling="Timing">
   </table>
   <table name="EGR Timing Advance" category="Timing" address="556a3" type="3D" level="1" swapxy="true" scaling="Timing">
      <table name="Load" address="5c1b2" type="X Axis" elements="9" scaling="Load"/>
      <table name="RPM" address="5c198" type="Y Axis" elements="10" scaling="RPM"/>
   </table>
   <table name="High Octane Fuel Map" category="Fuel" address="55027" type="3D" swapxy="true" scaling="AFR">
      <table name="RPM" address="5ea2a" type="Y Axis" elements="14" scaling="RPM"/>
   </table>
   <table name="Low Octane Fuel Map" category="Fuel" address="551a3" type="3D" swapxy="true" scaling="AFR">
   </table>
   <table name="High Octane Fuel Map #2" category="Fuel" address="550e5" type="3D" swapxy="true" scaling="AFR">
   </table>
   <table name="Low Octane Fuel Map #2" category="Fuel" address="55261" type="3D" swapxy="true" scaling="AFR">
   </table>
   <table name="Fuel Injector Scaling" category="Fuel" address="51b04" type="1D" scaling="InjectorScaling"/>
   <table name="Injector Battery Voltage Latency Compensation" category="Fuel" address="5544e" type="2D" scaling="InjectorLatency">
      <table name="Battery Voltage" address="5f08a" type="Y Axis" elements="7" scaling="BatteryVoltage"/>
   </table>
   <table name="Injector Base Latency" category="Fuel" address="51200" type="1D" scaling="InjectorLatency"/>
   <table name="MAF Scaling Part 1" category="Fuel" address="56a5a" type="2D" level="4" scaling="uint16">
      <table name="Volts" address="5f158" type="Y Axis" elements="44" scaling="VoltsADC1023"/>
   </table>
   <table name="MAF Scaling Part 2" category="Fuel" address="56ab2" type="2D" level="4" scaling="uint16">
      <table name="Volts" address="5f1b0" type="Y Axis" elements="44" scaling="VoltsADC1023"/>
   </table>
   <table name="MAF Scaling Part 3" category="Fuel" address="56b0a" type="2D" level="2" scaling="uint16">
      <table name="Volts" address="5f208" type="Y Axis" elements="42" scaling="VoltsADC1023"/>
   </table>
   <table name="Evap Map #1" category="Fuel" address="5586b" type="3D" level="2" swapxy="true" scaling="AFR">
      <table name="RPM" address="5f28e" type="Y Axis" elements="20" scaling="RPM"/>
   </table>
   <table name="Evap Map #2" category="Fuel" address="55977" type="3D" level="2" swapxy="true" scaling="AFR">
   </table>
   <table name="Open Loop Load Low Octane #1" category="Fuel" address="5534c" type="2D" level="4" scaling="Load8">
      <table name="RPM" address="5e90e" type="Y Axis" elements="16" scaling="RPM"/>
   </table>
   <table name="Open Loop Load High Octane #1" category="Fuel" address="569d8" type="2D" scaling="Load8">
   </table>
   <table name="Open Loop Load Low Octane #2" category="Fuel" address="55360" type="2D" level="2" scaling="Load8">
   </table>
   <table name="Open Loop Load High Octane #2" category="Fuel" address="569ec" type="2D" level="4" scaling="Load8">
   </table>
   <table name="Cylinder Fuel Trim #1" category="Fuel" address="5a4ed" type="3D" level="1" swapxy="true" scaling="AFR">
      <table name="Load" address="5b516" type="X Axis" elements="13" scaling="Load"/>
      <table name="RPM" address="5b490" type="Y Axis" elements="14" scaling="RPM"/>
   </table>
   <table name="Cylinder Fuel Trim #2" category="Fuel" address="54fa3" type="3D" level="1" swapxy="true" scaling="AFR">
   </table>
   <table name="Cylinder Fuel Trim #3" category="Fuel" address="55061" type="3D" level="1" swapxy="true" scaling="AFR">
   </table>
   <table name="Cylinder Fuel Trim #4" category="Fuel" address="5511f" type="3D" level="1" swapxy="true" scaling="AFR">
   </table>
   <table name="Throttle Map #1" category="Intake" address="5062a" type="3D" level="2" swapxy="true" scaling="Throttle Opening">
      <table name="X" address="5ef78" type="X Axis" elements="17" scaling="Load"/>
      <table name="Y" address="5f43a" type="Y Axis" elements="14" scaling="RPM"/>
   </table>
   <table name="Throttle Map #2" category="Intake" address="50427" type="3D" level="1" swapxy="true" scaling="Throttle Opening">
      <table name="X" address="5c0a2" type="X Axis" elements="17" scaling="Load"/>
      <table name="Y" address="5bc08" type="Y Axis" elements="14" scaling="RPM"/>
   </table>
   <table name="Throttle Map #3" category="Intake" address="57628" type="3D" level="1" swapxy="true" scaling="Throttle Opening">
   </table>
   <table name="Throttle Conditional Switch" category="Intake" address="526c2" type="1D" level="1" scaling="RPMStatLimit"/>
   <table name="Rev Limiter" category="Limits" address="5125e" type="2D" scaling="RPMLimit">
      <table type="Static Y Axis" elements="2">
         <data>Rev Limiter ON</data>
         <data>Rev Limiter OFF</data>
      </table>
   </table>
   <table name="Stationary Rev Limiter" category="Limits" address="5162e" type="1D" level="1" scaling="RPMStatLimit"/>
   <table name="Speed Limiter" category="Limits" address="51262" type="2D" scaling="VehicleSpeed">
      <table name="X" type="Static Y Axis" elements="2">
         <data>Limiter ON</data>
         <data>Limiter OFF</data>
      </table>
   </table>
   <table name="Airflow Check #1" category="Limits" address="5a5dd" type="3D" level="3" swapxy="true" scaling="uint8">
      <table name="TPS Related" address="5d022" type="X Axis" elements="14" scaling="Throttle %"/>
      <table name="RPM" address="5cffe" type="Y Axis" elements="15" scaling="RPM"/>
   </table>
   <table name="Airflow Check # 2" category="Limits" address="5a6b7" type="3D" level="3" swapxy="true" scaling="uint8">
   </table>
   <table name="Airflow Check #3" category="Limits" address="5defb" type="3D" level="3" swapxy="true" scaling="uint8">
      <table name="TPS-Related" address="5d022" type="X Axis" elements="14" scaling="Throttle %"/>
   </table>
   <table name="Torque Limiter #1" category="Limits" address="5dfd5" type="3D" level="3" swapxy="true" scaling="uint8">
   </table>
   <table name="Torque Limiter #2" category="Limits" address="5e769" type="3D" level="3" swapxy="true" scaling="uint8">
   </table>
   <table name="Torque Limiter #3" category="Limits" address="5e843" type="3D" level="3" swapxy="true" scaling="uint8">
   </table>
   <table name="Idle RPM #1 vs Coolant Temp" category="Idle" address="55b42" type="2D" level="2" scaling="RPM8">
      <table name="Coolant Temperature" address="5bd02" type="Y Axis" elements="8" scaling="Temp"/>
   </table>
   <table name="Idle RPM #2 vs Coolant Temp" category="Idle" address="55b4e" type="2D" level="2" scaling="RPM8">
   </table>
   <table name="Idle RPM #3 vs Coolant Temp" category="Idle" address="56104" type="2D" level="2" scaling="RPM8">
   </table>
   <table name="Idle RPM #4 vs Coolant Temp" category="Idle" address="56126" type="2D" level="2" scaling="RPM8">
   </table>
   <table name="Idle RPM #5 vs Coolant Temp" category="Idle" address="56132" type="2D" level="2" scaling="RPM8">
   </table>
   <table name="Idle RPM #6 vs Coolant Temp" category="Idle" address="53b52" type="2D" level="2" scaling="RPM8">
   </table>
   <table name="Target Idle #1" category="Idle" address="515bc" type="1D" level="2" scaling="RPMTarget"/>
   <table name="Target Idle #2" category="Idle" address="513c6" type="1D" level="2" scaling="RPMTarget"/>
   <table name="OBD-II Codes" category="ODB-II" address="95220" type="3D" scaling="Hex16">
      <table name="r4 (hex)" type="Static X Axis" elements="16">
         <data>8000</data>
         <data>4000</data>
         <data>2000</data>
         <data>1000</data>
         <data>800</data>
         <data>400</data>
         <data>200</data>
         <data>100</data>
         <data>80</data>
         <data>40</data>
         <data>20</data>
         <data>10</data>
         <data>8</data>
         <data>4</data>
         <data>2</data>
         <data>1</data>
      </table>
      <table name="r5 (hex)" type="Static Y Axis" elements="16">
         <data>00</data>
         <data>01</data>
         <data>02</data>
         <data>03</data>
         <data>04</data>
         <data>05</data>
         <data>06</data>
         <data>07</data>
         <data>08</data>
         <data>09</data>
         <data>0A</data>
         <data>0B</data>
         <data>0C</data>
         <data>0D</data>
         <data>0E</data>
         <data>0F</data>
      </table>
   </table>
   <table name="ECU Options Set #1" category="ECU Options" address="50072" type="2D" scaling="blobbits">
      <table name="Periphery Bit Number" type="Static Y Axis" elements="16">
         <data>bit.15</data>
         <data>bit.14</data>
         <data>bit.13</data>
         <data>bit.12</data>
         <data>bit.11</data>
         <data>bit.10</data>
         <data>bit.9</data>
         <data>bit.8</data>
         <data>bit.7</data>
         <data>bit.6</data>
         <data>bit.5</data>
         <data>bit.4</data>
         <data>bit.3</data>
         <data>bit.2</data>
         <data>bit.1</data>
         <data>bit.0</data>
      </table>
   </table>
   <table name="ECU Options Set #2" category="ECU Options" address="50082" type="2D" scaling="blobbits">
         <data>bit.15</data>
         <data>bit.14</data>
         <data>bit.13</data>
         <data>bit.12</data>
         <data>bit.11</data>
         <data>bit.10</data>
         <data>bit.9</data>
         <data>bit.8</data>
         <data>bit.7: Enable Knock Retard</data>
         <data>bit.6</data>
         <data>bit.5</data>
         <data>bit.4</data>
         <data>bit.3</data>
         <data>bit.2</data>
         <data>bit.1 rear O2</data>
         <data>bit.0</data>
      </table>
   </table>
   <table name="ECU Options Set #3" category="ECU Options" address="50092" type="2D" scaling="blobbits">
         <data>bit.15</data>
         <data>bit.14: Cruise Control Enabled/Disabled</data>
         <data>bit.13</data>
         <data>bit.12</data>
         <data>bit.11</data>
         <data>bit.10</data>
         <data>bit.9</data>
         <data>bit.8</data>
         <data>bit.7</data>
         <data>bit.6</data>
         <data>bit.5</data>
         <data>bit.4</data>
         <data>bit.3</data>
         <data>bit.2</data>
         <data>bit.1</data>
         <data>bit.0: Lean Spool Off/On</data>
      </table>
   </table>
   <table name="ECU Options Set #4" category="ECU Options" address="500a2" type="2D" scaling="blobbits">
         <data>bit.15</data>
         <data>bit.14</data>
         <data>bit.13</data>
         <data>bit.12</data>
         <data>bit.11</data>
         <data>bit.10</data>
         <data>bit.9</data>
         <data>bit.8</data>
         <data>bit.7</data>
         <data>bit.6</data>
         <data>bit.5</data>
         <data>bit.4</data>
         <data>bit.3</data>
         <data>bit.2</data>
         <data>bit.1</data>
         <data>bit.0</data>
      </table>
   </table>
   <table name="ECU Options Set #5" category="ECU Options" address="500b2" type="2D" scaling="blobbits">
         <data>bit.15</data>
         <data>bit.14</data>
         <data>bit.13</data>
         <data>bit.12</data>
         <data>bit.11</data>
         <data>bit.10</data>
         <data>bit.9</data>
         <data>bit.8</data>
         <data>bit.7</data>
         <data>bit.6</data>
         <data>bit.5</data>
         <data>bit.4</data>
         <data>bit.3</data>
         <data>bit.2</data>
         <data>bit.1</data>
         <data>bit.0</data>
      </table>
   </table>
   <table name="ECU Options Set #6" category="ECU Options" address="500c2" type="2D" scaling="blobbits">
         <data>bit.15</data>
         <data>bit.14</data>
         <data>bit.13</data>
         <data>bit.12</data>
         <data>bit.11</data>
         <data>bit.10</data>
         <data>bit.9</data>
         <data>bit.8</data>
         <data>bit.7</data>
         <data>bit.6</data>
         <data>bit.5</data>
         <data>bit.4</data>
         <data>bit.3</data>
         <data>bit.2</data>
         <data>bit.1</data>
         <data>bit.0</data>
      </table>
   </table>
   <table name="ECU Options Set #7" category="ECU Options" address="500d2" type="2D" scaling="blobbits">
         <data>bit.15</data>
         <data>bit.14</data>
         <data>bit.13</data>
         <data>bit.12</data>
         <data>bit.11</data>
         <data>bit.10</data>
         <data>bit.9</data>
         <data>bit.8</data>
         <data>bit.7</data>
         <data>bit.6</data>
         <data>bit.5</data>
         <data>bit.4</data>
         <data>bit.3</data>
         <data>bit.2</data>
         <data>bit.1</data>
         <data>bit.0</data>
      </table>
   </table>
   <table name="MUT Table" category="MUT" address="3624c" type="3D" level="2" scaling="MUT32">
      <table name="X" type="Static X Axis" elements="16">
         <data>0</data>
         <data>1</data>
         <data>2</data>
         <data>3</data>
         <data>4</data>
         <data>5</data>
         <data>6</data>
         <data>7</data>
         <data>8</data>
         <data>9</data>
         <data>A</data>
         <data>B</data>
         <data>C</data>
         <data>D</data>
         <data>E</data>
         <data>F</data>
      </table>
      <table name="Y" type="Static Y Axis" elements="30">
         <data>MUT0X</data>
         <data>MUT1X</data>
         <data>MUT2X</data>
         <data>MUT3X</data>
         <data>MUT4X</data>
         <data>MUT5X</data>
         <data>MUT6X</data>
         <data>MUT7X</data>
         <data>MUT8X</data>
         <data>MUT9X</data>
         <data>MUTAX</data>
         <data>MUTBX</data>
         <data>MUTCX</data>
         <data>MUTDX</data>
         <data>MUTEX</data>
         <data>MUTFX</data>
         <data>MUT10X</data>
         <data>MUT11X</data>
         <data>MUT12X</data>
         <data>MUT13X</data>
         <data>MUT14X</data>
         <data>MUT15X</data>
         <data>MUT16X</data>
         <data>MUT17X</data>
         <data>MUT18X</data>
         <data>MUT19X</data>
         <data>MUT1AX</data>
         <data>MUT1BX</data>
         <data>MUT1CX</data>
         <data>MUT1DX</data>
      </table>
   </table>
   <table name="newTable" type="3D" level="1">
      <table name="X" type="X Axis"/>
      <table name="Y" type="Y Axis"/>
   </table>
</rom>
wcgomes
Postby gagak_84 » Tue Jun 24, 2014 6:06 am
your stock ROM is a error man.... pls read again using tactrix.... and upload here,,,
gagak_84
