ACD Reflash ?????
ACD Reflash ?????
Postby M3This » Tue May 16, 2006 1:27 pm
Anyone know if the ECU Flash will work on the ACD ECU ??? I know some of the tunners in Japan actually reflash the ACD and I havnt been able to see anyone here in the US be able to do it yet.
M3This
Postby galvitron » Wed May 17, 2006 1:45 pm
I believe you would need a harness either custom made or from Mitsu. And I believe Mitsu would not provide this to the public (not sure). You may have to contact someone like Ralliart directly (they make ACD controllers that are pre-flashed to different 'sportiness' that you can buy off their website), but good luck on that if you aren't running a Rally team or something...
If you have any links to Japanese resources on this I can translate them for everybody.
galvitron
Postby wattsg » Thu May 18, 2006 12:17 am
I have access to a 'spare' evo 6 AYC unit, i'll take it to bits and get photos.
It's not ACD .. but it's a start for us people with JDM cars.
g.
wattsg
Postby Hurrikain » Sat May 27, 2006 5:27 pm
http://www.takakaira.com/asp/template.a ... IidfEgcjFe
Ralliart supplied reflashed ACD. Ships from Japan though.
Hurrikain
Postby GTODesign » Sun May 28, 2006 1:02 am
IIRC the processor used for the ACD is a derivative of the core processor used in E5/6 ECU's. If so, then when the E5/6 kernel is finished there's half a hope of it working straight out of the box, maybe subject to a bit of wiring.
GTODesign
Postby cboles » Sun May 28, 2006 9:33 am
Exactly :)
Postby M3This » Fri Oct 20, 2006 2:12 pm
Anyone see that Motec has released a fully adjustable ACD for the Evo? its well over a $1,000 :shock:
M3This
Postby Hurrikain » Sun May 13, 2007 3:28 pm
Any developments?
Hurrikain
Postby NeverLies » Mon May 14, 2007 6:36 am
Kernel is still not published so no way to flash it with this solution :(
