Problem with Airtrek Ecu
Postby thirdeyes » Thu Dec 01, 2011 7:16 am
hi guys ,
i'm using 2002 , mitsukenel ,Sh7052 . been having problem trying to convert my file From 256kbs to 512kbs . can any one help me with the steps pls ? with out the convert i am having problem with gear boost limit lock .
SA1668J.hex
(256 KiB) Downloaded 721 times
thirdeyes
Re: Problem with Airtrek Ecu
Postby radsdau » Thu Dec 01, 2011 2:56 pm
If it's SH7052, the ROM is 256kB. SH7055 use 512kB ROM. There is no 'converting' a 256k ROM to 512k; they're totally different animals. It's like 'converting' a motorbike to a bus.
Postby thirdeyes » Thu Dec 15, 2011 2:31 am
tyvm Radsdau for saving my time
thirdeyes
Postby thirdeyes » Wed Dec 21, 2011 6:41 am
i just done my 7052 to 7055 .. now 512kbs ..
thirdeyes
Postby radsdau » Wed Dec 21, 2011 3:02 pm
Did the car run?
Postby thirdeyes » Thu Dec 22, 2011 12:55 am
very well , without having problem with gearbox boost cut now !
thirdeyes
Postby radsdau » Mon Jan 02, 2012 3:43 pm
Wow, I am surprised. Glad it works for you. I learned something new today.
Postby radsdau » Tue Jan 03, 2012 3:46 pm
I don't know what the code is that is normally in the second 256kb, but if you use a ROM intended for 7052 (256kb), I suppose it won't reference any code above 256k, so it shouldn't hit any 'invalid memory' traps.
Sounds like the memory and register mapping is similar enough (or exact) so the 7052 rom still runs in a 7055.
There will be some functionality missing though, don't know what.
Can anyone tell us what the small amount of code in the second 256k in a 7055 does?
Postby thirdeyes » Sun Jan 15, 2012 3:13 am
the other half 256kb let you tune your Gear shift timing and pressure .and other more stuff
thirdeyes
Users browsing this forum: No registered users and 38 guests
