EVO 5 CP9A can't read ECU
Postby KurumaOtaku » Fri Jul 01, 2011 4:37 pm
I just picked up an EVO 5 RS and hooked up my laptop and tactrix cable to check out the ecu and change a few things however I can't read the ECU. With this same laptop/cable setup I used to be able to read my old EVO 8 just fine. I was using the 1.3 cable and version 1.42 of ecuFlash. I then upgraded to the 1.43 beta to see if that would fix it but the same thing happens. I've also tried to use the ECU unlocker with no success.
This is the message I get in my log:
[09:29:37.632] Using interface OpenPort 1.3 Mitsubishi TX37zgV3ca27b4d910f950f7546eaee4a4af243719d27c2f
[09:29:41.044] sending init sequence 2
[09:29:41.055] got 0x11 response
[09:29:41.060] sending init sequence 3
[09:29:41.443] entering bootloader
[09:29:41.459] sending kernel size (2029)
[09:29:41.481] sending kernel load address (0x0000F000)
[09:29:41.503] uploading kernel
[09:29:41.830] verifying kernel checksum response
[09:29:41.840] kernel valid
[09:29:42.056] kernel get version
[09:29:42.077] kernel version is : OpenEcu Mitsubishi H8/539F Kernel V1.07
[09:29:42.077] reading kernel comm buffer size
[09:29:42.088] comm buffer size set to 256
[09:29:42.088] reading kernel flash buffer size
[09:29:42.099] flash buffer size set to 1024
[09:29:42.112] interface close
Any help into getting into my ECU????
KurumaOtaku
Re: EVO 5 CP9A can't read ECU
Postby ptharris » Sat Jul 02, 2011 8:45 pm
You need OP 2.0 to reflash Evo 5,6,6.5!!!!!
I have a 2nd hand 1 for sale, PM if interested
Cheers
ptharris
